He fellow's I have 03 f 350 drw lararit 6.0 4x4. I have no power to transfer case motor, changed both relays underhood checked all fuses in cab all were good, except for fuse 31 no power . Im going nuts, can anybody point me in the right direction I need my 4x4. Also lights on dash come on during start up. I have put a motor and transmission in this truck I bought not running had sat for 3yrs got screwed but that's another story. Thank guys hope someone can help
Transfer casr bob cat, I manually locked them in other day cause of big snow here in tn, and I couldn't get outa my driveway cause the transfer case would not engage to get front wheels to pull. Thanks bobcat for answering my post
Have not checked that, I did think bought checking the switch and plug, any certain thing I should b looking for? I will check and let u know . Thank u bobcat.
Just check the wires with key on and you should be able to see when you switch it to high and low the wires will show hot and move to another wire when you switch it. If that makes since. Should be one hot wire all the time.
K im wit ya, to check that is that the other pig tail above pig tail going to transfer motor? Or are you telling me to pull switch outa dash and check it unplugged with meter as I select 4h or 4l. Im just askin specific so I do the right things. Once again thank u.
I would check the pigtail at the transfer case first. See if there is any juice to it. If not then check the switch itself in the dash since you already checked the fuses.
Hey sorry its took me a min, just checked 6pin con going to shift motor had volts there. No power going to two pin pig tell going to motor. I pulled motor of put voltage on motor and it works. Not what?
