Sponsored by: Real Truck
4x4 problems
Old Aug 19, 2012 | 04:27 PM
Collinsmatt's Avatar
Collinsmatt
4x4 problems
I have a 2001 ford f 250 with v10. My 4x4 is not working. All fuses are good. The relays are good. What next? How can I tell if it's the switch, the transfer case motor, or the gem. Any help would be appreciated.thanks
Old Aug 19, 2012 | 08:33 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
What are the symptoms. It's probably $4 worth of vacuum hose.
Old Aug 19, 2012 | 08:35 PM
acf6's Avatar
acf6
probably a vacuum leak. if you manually lock the hubs up front and then engage 4x4 in the cab, does the system work?
Old Aug 19, 2012 | 09:36 PM
Collinsmatt
The problem is the transfer case is not getting power. No lights in dash. No clicks. Nothing. Manually locking the hubs is irrelevant if the transfer case goes not engage. Maybe the next step is to bench test the transfer case motor and see if it's good
Old Aug 19, 2012 | 09:43 PM
acf6's Avatar
acf6
That would have been helpful to know before...the motor might be shot. I think there is a way you can manually engage the transfer case if you take the motor off but I don't know how
Old Aug 19, 2012 | 09:56 PM
deck60's Avatar
deck60
this is what it looks like without the motor on except for the hole and threads I made mine into a manual shift just turn it it will to engage all gears except neutral you have detents for 2h 4h 4l
Old Aug 19, 2012 | 10:03 PM
AnnLindel's Avatar
AnnLindel
BigBlackF-250
Mar 17, 2015 08:25 AM
Tedesco
Apr 2, 2014 06:53 AM
diesel pup
Feb 17, 2014 03:50 PM
metalhead132
1997 - 2003 F150
Jul 3, 2011 12:47 PM
yachtonwheels
Oct 1, 2010 08:50 AM
