Sponsored by: Auxito
98 3rd brake light
Old Jun 29, 2003 | 10:16 PM
ob1bnl's Avatar
ob1bnl
Unhappy 98 3rd brake light
Hi all,
hopefully an easy one for ya's. I have a '98 f-150 4x4 s-cab, etc. with a broken 3rd brake light(worker hit it with something). I ordered a new light and went to install it, but seems i need to take out my headliner to do so.
Is that the case? please let me know either way. I either need to know that I need to take it out, or that I can reach the harness above the headliner w/o ruining it.
I will greatly appreciate the info.
OB
Old Jun 30, 2003 | 11:33 AM
f150-az's Avatar
f150-az
98 3rd brake light
I think I'm gonna answer your question with a stupid question. What is the headliner? I know how to replace the third brake light on my 97 but dont know anything of any headliner.
Old Jun 30, 2003 | 12:34 PM
ob1bnl's Avatar
ob1bnl
98 3rd brake light
Hi F150 AZ,
First, there is no such thing as a stupid question...lol.
The headliner I'm referring to is the one inside my cab. The wiring harness for the 3rd brake light unit goes through the cab and plugs in somewhere under the headliner.
My question is: can I get to where it plugs in under the headliner without removing the headliner? If not, what size Torx bit do I need to get the seat belts off so that I can remove the headliner?
OB
Old Jun 30, 2003 | 01:10 PM
f150-az's Avatar
f150-az
98 3rd brake light
First off, did you try to get to the wiring harness from the outside of the cab? I have had my 3rd light apart a couple of times but never really rooted around in there to see where the harness is. I'm pretty sure you can access it from the outside but if not, then the torx bit number is 55. I had my seats out an stuff a while ago and that's the size you'll need.
Old Jun 30, 2003 | 04:05 PM
MrBSS's Avatar
MrBSS
98 3rd brake light
I had my 3rd brake light out to put in the Lightning LED unit. Mine is a 2001, so it may be different. The plug is pretty far in, but I was able to get to it by popping out the 2 plastic fasteners and the side panels holding the headliner up. Did NOT need to loosen the belt harness.
Old Jun 30, 2003 | 04:24 PM
peterbilt's Avatar
peterbilt
98 3rd brake light
I have Scab and if you don't have a back window slider it is a pain to change. I had to pull out the seat back and the side panels above the seat back. Then, remove the coat hooks and carefully pull down the back of the head liner. There is a connector in the center of the roof under the headliner.
Pete
Old Jul 1, 2003 | 03:48 PM
ob1bnl's Avatar
ob1bnl
Thumbs up 98 3rd brake light
All set!!!
Truck had to go to the dealers today because another ford dealer f***cked up my front end. When I was there I asked about it. Tech had a great idea......since the harness was good, and i just needed to change the plastic that was broken, they just left the harness in and switched out the plastic(yes, i'm an idiot)
So all set on that front. I appreciate all the input
Old Jul 1, 2003 | 03:51 PM
peterbilt's Avatar
peterbilt
98 3rd brake light
ob1bnl
That makes two of us
Pete
Old Jul 1, 2003 | 04:05 PM
ob1bnl's Avatar
ob1bnl
98 3rd brake light
Pete...you tellin me all you had to change was the lens too??? Please say yes & make my day!!! LOLOL
Old Jul 1, 2003 | 04:34 PM
peterbilt's Avatar
peterbilt
98 3rd brake light
ob1bnl
It was an education. I spilled touch up paint on the lens and it etched the lens while trying to clean it (long story). It would probably been OK, but the truck was new. I can't wait to get home tonight and look at the old assembly.
Pete
Old Jul 1, 2003 | 08:52 PM
ob1bnl's Avatar
ob1bnl
Talking 98 3rd brake light
Sorry you had to go through all the trouble Pete. Sometimes I wish I woulda stayed in the common sense line when they were handin it out. After the tech said it, I said YEAH! that makes sense!!!!! And I kept the new harness just in case it went bad. Plus, I have all those new bulbs too!!! WOOOHOOOOO....LOL
OB
jse1958
1997 - 2003 F150
Feb 17, 2022 09:18 PM
Superduty450
2004 - 2008 F150
Oct 27, 2014 01:19 PM
Tanner2255
Oct 26, 2011 11:59 AM
ruli00
2004 - 2008 F150
Feb 26, 2011 05:00 PM
mustangski
2004 - 2008 F150
15
Jul 31, 2009 11:20 PM
