Sponsored by: Real Truck
Not sure what classify this problem as..
Old Feb 13, 2014 | 11:12 PM
FordTruckEnthusaist's Avatar
FordTruckEnthusaist
So I changed out my dome/map lights out with some LED ones. The map lights work, but the dome and cargo light won't work now. I got in the truck and started it up, and the truck won't shift into reverse. The lever is stuck, just like if you tried to put it in gear without pressing the brake, and the little screen that displays the temperature and all the climate controls doesn't work, heater won't come on.
I can't think of any way this could be related to me changing the dome lights but WTF it drove perfectly fine before. Possible I blew a fuse? I went through and checked all the fuses with my DVM in the cab and all the mini fuses were good. I don't know how to test the big relays or the pink fuses. And I didn't test the fuses in the engine compartment. Can anyone get me off on the right track here please?
Old Feb 14, 2014 | 05:22 AM
redford's Avatar
redford
FTE Leadership Emeritus
You could try this:
Brake-shift interlock
This vehicle is equipped with a brake-shift interlock feature that prevents
the gearshift lever from being moved from P (Park) when the ignition is
in the 4 (ON) position unless brake pedal is depressed.
If you cannot move the gearshift lever out of P (Park) with ignition in
the 4 (ON) position and the brake pedal depressed:
1. Apply the parking brake, turn ignition key to 2 (LOCK), then remove
the key.
2. Insert the key and turn it to 3 (OFF). Apply the brake pedal and
shift to N (Neutral).
When the key is in the ignition and in the OFF position, the
automatic transmission shift lever can be moved from the P
(Park) position without the brake pedal depressed. To avoid unwanted
vehicle movement, always set the parking brake.
3. Start the vehicle.
If it is necessary to use the above procedure to move the gearshift lever,
it is possible that a fuse has blown or the vehicle’s brakelamps are not
operating properly. Refer to Fuses and relays in the Roadside
Emergencies chapter.
Old Feb 14, 2014 | 06:06 AM
madsonp's Avatar
madsonp
LED bulbs must be inserted correctly due to the polarity, positive to positive and negative to negative. Having them in backwards will cause them not to work, and I would think could cause other issues.
Old Feb 14, 2014 | 07:54 AM
FordTruckEnthusaist
Originally Posted by redford
You could try this: Brake-shift interlock This vehicle is equipped with a brake-shift interlock feature that prevents the gearshift lever from being moved from P (Park) when the ignition is in the 4 (ON) position unless brake pedal is depressed. If you cannot move the gearshift lever out of P (Park) with ignition in the 4 (ON) position and the brake pedal depressed: 1. Apply the parking brake, turn ignition key to 2 (LOCK), then remove the key. 2. Insert the key and turn it to 3 (OFF). Apply the brake pedal and shift to N (Neutral). When the key is in the ignition and in the OFF position, the automatic transmission shift lever can be moved from the P (Park) position without the brake pedal depressed. To avoid unwanted vehicle movement, always set the parking brake. 3. Start the vehicle. If it is necessary to use the above procedure to move the gearshift lever, it is possible that a fuse has blown or the vehicle’s brakelamps are not operating properly. Refer to Fuses and relays in the Roadside Emergencies chapter.
Will try this, then I guess I need to check my fuses in the engine compartment as well.
Yeah I noticed they had to be put in a certain way for them to light up, and I had them working before I re mounted the dome light then I got it all on and tried to turn them on and nothing?
Old Feb 14, 2014 | 08:35 AM
Powelligator's Avatar
Powelligator
Did you try putting the old bulbs back in? I can't imagine the LED's themselves causing problems like this, what happens when a convention lightbulb burns out under normal conditions...
-Joe
Old Feb 14, 2014 | 08:46 AM
FordTruckEnthusaist
Yeah I tried putting the old bulbs back in and nothing. The map lights work fine.
duggyb
Nov 24, 2014 04:51 PM
felixc
1997 - 2003 F150
Apr 3, 2007 03:26 PM
dietzx5
Aerostar
Jan 25, 2006 10:52 PM
The Mad Canoeist
Nov 22, 2005 06:24 PM
jonjamky
May 21, 2003 07:56 PM
