2009 ABS light
Old Feb 13, 2014 | 07:24 PM
brent1204's Avatar
brent1204
2009 ABS light
I changed the front brakes and rotters on my 09 f150 and now sometimes my ABS light as well as my anti skid light comes and stays on until I turn truck off my not come back on for a couple of weeks or my come on the next time I crank truck?
Old Feb 13, 2014 | 08:25 PM
Tom's Avatar
Tom
I'm thinking you may have damaged one of your wheel speed sensors. If you know someone with a scan tool capable of reading those codes that would be the first step. If not I'd take a good visual look at the sensors and see if anything looks amiss. Also check the connector, maybe it was knocked loose?
Old Feb 13, 2014 | 08:29 PM
derek4343's Avatar
derek4343
Try disconnecting your battery for ten to fifteen minutes to clear the lights. See if that'll help
Old Feb 13, 2014 | 10:18 PM
Trailblazen's Avatar
Trailblazen
WAIT! DO NOT disconnect until he can try to read the codes. That just covers up the issue and with brakes you don't want to mess around. He needs to actually troubleshoot this like Tom mentioned and get his codes checked to try to narrow this down. Clearing the codes without checking them is like closing your eyes in a fire, even though you can't see it the fire is still there. Also need to do a visual inspection to make sure everything is snugly plugged and not damaged.
motorhead5673
1997 - 2003 F150
Dec 8, 2009 07:32 PM
alz
1978 - 1996 Big Bronco
Nov 21, 2007 04:49 PM
Lynch02
1983 - 2012 Ranger & B-Series
Oct 10, 2006 11:46 AM
shane7209
1997 - 2003 F150
Mar 8, 2003 11:30 PM
