Quick question - fuel leak
Old Feb 12, 2014 | 12:25 PM
cowmilker08's Avatar
cowmilker08
Question Quick question - fuel leak
I have the notorious leaky fuel filter restriction sensor.
I bought galvanized pipe plugs to replace the sensor. Should I have bought brass instead or will the galvanized steel be ok?
Old Feb 12, 2014 | 05:55 PM
farmert's Avatar
farmert
The steel one you have will work fine. Remember, don't over tighten it.
Old Feb 12, 2014 | 07:37 PM
madMatador78's Avatar
madMatador78
I'm curious to know if they need to be tefloned. I think that's where someone went wrong with mine cause it was just stuffed with Teflon.
Hope you get it fixed Phil, nothing is not frustrating than fuel leaks.
Old Feb 13, 2014 | 07:57 AM
cowmilker08
I think you are supposed to use thread tape, but it has to be rated for diesel service. The typical white stuff doesn't last when used with diesel. I bought a roll of Blue Monster PTFE thread tape.
Old Feb 13, 2014 | 08:04 AM
fordpride's Avatar
fordpride
A lot of people don't know how to use teflon. They just wrap the hell out of it when it should only have just enough to cover the threads.
Old Feb 13, 2014 | 08:52 AM
cowmilker08
And most don't know that there is a right and wrong direction to wrap it.
This stuff I bought says to wrap the threads three times, but that seems a bit excessive for 1/8" pipe threads.
green_95
Nov 25, 2015 04:45 PM
Royson12
Jan 19, 2013 08:00 AM
coreylasalle
Apr 25, 2011 08:56 PM
Hussler
13
Dec 19, 2007 05:54 PM
efudd
Oct 29, 2003 08:27 PM
