High Beam Wire
If I understand your post correctly, you are installing extra lights that you only want on when two conditions are met: 1) you turn upfitter 1 on and 2) you have high beams on.
I have not done this, but looking at the factory wiring diagrams, you can access the high beam power wires at the BCM. Wires 7 and 8 in plug C2280E are for the right and left high beams respectively. Wire 7 is Violet-Orange and wire 8 is Gray-Brown. To locate plug C2280E, find fuse F48 (it sits in a corner), the plug you want sits 45 degrees from that corner. It has 10 total pins in it.
Obviously check things with a VOM. Another option would be to pull the grill off and access these wires at one of the headlights. Wire colors remain the same.
Again, this is only from looking at the wiring diagrams and not actually verifying on the truck.
Hope this helps.
Bob
Are your lights powered off the battery with your up fitter energizing the relays? Or is the power for the lights coming through the relay from the up fitter?
I'm doing two 30" light bars (only 25A total), but powering the lights off the battery terminal and going to a drilled chassis ground made solely for the front aux. lighting. Upfitter 1 will energize both relays, with the high beam wire being my switch reference.
This diagram as an example, your upfitter would be at the switch on/off, and switch power (by #3) gets tied in to your high beam wire. Essentially little load gets applied to the upfitter, it acts as a switch for your lights. Upfitter off, still have high beams. Upfitter on with high beams you'll get aux. lighting.
PIAA Relay Diagram
I'm thinking this is what your old truck had going on. I'm not sure if you wanted to buy a harness or if the relay your using had a type of reference terminal like this...
The wiring instructions you see about accessing the back of the switch and using both sets of terminals is for a different setup than you have in your truck. The upfitter switches control a relay. That relay only has a single set of terminals. So, disregard the instructions you found.
What is the combined amperage draw of all four of your Lightforce lights?
For my understanding, is this how you have your lights wired up:
You have two relays installed, one for the left side lights and one for the right side lights.
LEFT Relay
85 Ground
86 Left highbeam
30 Upfitter 1
87 Left Lightforce lights
RIGHT Relay
85 Ground
86 Right highbeam
30 Upfitter 1
87 Right Lightforce lights
Because you are using Upfitter 1 to provide power through both relays to all 4 lights, you are limited to a maximum of 25 amp total draw. If your Lightforce lights draw more than 25amps combined, your wiring setup will not work.
If your lights draw combined less than 25 amps, I see no need for two relays. Why not wire like this?
Relay 1
85 Ground
86 either highbeam (doesn't matter which one)
30 Upfitter 1
87 all 4 Lightforce lights
You still get 25 amps total but remove one relay from the mix as it is unnecessary.
If your lights draw more than 25 amps but less than 30 amps combined, try wiring like this:
Relay 1:
85 Ground
86 either highbeam
30 Upfitter 1
87 Relay 2 pin 86
Relay 2:
85 Ground
86 from relay 1
30 from battery (with 30 amp inline fuse)
If your lights draw more than 30 amps combined but less than 15 amps each (less than 30 amps per side), try this:
Relay 1:
85 Ground
86 either highbeam
30 Upfitter 1
87 Relay 2 and relay 3 pin 86
Relay 2:
85 Ground
86 from relay 1
87 Left 2 Lightforce lights
Relay 3:
85 Ground
86 from relay 1
30 from battery (with 30 amp inline fuse, different wire than goes to relay 2)
87 Right 2 Lightforce lights
This will allow each pair of lights to pull 30 amps and still require both upfitter 1 and the highbeams to be on in order for the Lightforce lights to turn on.
For a DC system,
voltage * amperage = wattage, so
amperage = wattage divided by voltage
Assuming a 100 watt bulb in each light:
amperage = 100/12 = 8.333 amps per light
8.333 * 4 = 33.333 amps for 4 lights. (16.667 amps per set of lights)
Bob
Thanks for thinking all this through.. I'm quite good with the electrical stuff as I come from a family of electricians.... but hearing it from someone like you who knows how and why to wire it a certain way is comforting to say the least..
Thanks again for your time to describe it in detail like you did. Appreciate it and will keep you posted on how it works out.
Hope this helps.
Bob[/QUOTE
Hello Bob,
I just bought my first Super Duty, 2016, and its outfitted with the upfitter switches. I have two HID driving lights ready to mount into bumper. I plan to use a SPST relay that will be triggered by the high beam.
I would like to mount the relay under dash and tap into a high beam lead under the dash, if possible. I am just wondering if your description of high beam wiring/plug/fuse might be the same and if i can find this wiring under the dash!
Thanks,
John P.
Accessing the high beam wires under the dash will be more of a challenge than what a mortal man will probably want to do. I recommend that you locate the highbeam wire where it plugs into the headlamp. I accessed the one on the passenger side. Was easy to find and to tap. I prefer Posi-Taps over the standard crimp with pliers style wire taps.
https://www.posi-products.com/posiplug.html
You can get them from Amazon or sometimes from Napa stores.
If you use a standard automotive relay with a mount hole, the relay can be easily mounted to one of the bolts that holds the air dam to the bumper. Works great, easy to access and wire. A relay socket like this http://tinyurl.com/zk3hova will make wiring much cleaner.
From there, determine the amperage draw of your HID driving lights and choose the appropriate wiring method from my post above.
Less than 25 amps for the two lights only requires the one relay.
More than 25 amps but less than 30 amps requires two relays.
More than 30 amps will require three relays.
Hope that answers your question.
Bob
