Heater wiring
Old Feb 11, 2014 | 07:25 PM
1978fordshort's Avatar
1978fordshort
Heater wiring
Alright guys it's freezing cold out and my heater does not work. 1977 f150 I have power to both side of the fuse and the orange wire to the the switch is hot at the fuse block but dead at the switch I found one connected 4 inches or so from the switch but it's dead there too. According to my Haynes there is no connectors anywhere else. So does anyone know why I won't have power?
Old Feb 11, 2014 | 09:56 PM
Tedster9's Avatar
Tedster9
All I can think is run a jumper wire of suitable size around the switch direct to the blower motor and see if it will run that way. It's never something simple like a switch, but might help eliminate something as a problem? Be careful as this is not a fused connection, but useful for troubleshooting.
Old Feb 12, 2014 | 06:13 AM
User 71024's Avatar
User 71024
Do you have A/C?
Old Feb 12, 2014 | 07:54 PM
1978fordshort
I did but someone ripped it all out. And a correction I was looking at the wrong wire at the fuse box. I took the box off the firewall and tested the correct orange wire. No power at all. So is there any way to bypass the fuse box there or do I have to replace the box?
Old Feb 12, 2014 | 08:04 PM
fmc400's Avatar
fmc400
MSEE
I don't understand what you're saying. Check power on BOTH sides of the heater fuse. Do you have power on NEITHER, ONE, or BOTH sides?
Old Feb 12, 2014 | 09:16 PM
1978fordshort
I have power at both sides of the fuse but none on the wire.
timstheman5
Electrical Systems/Wiring
Nov 24, 2014 02:33 PM
VGA57
Jul 7, 2013 05:31 PM
gotjeepzj
Jul 10, 2010 10:04 AM
pipman76
Mar 18, 2008 05:26 PM
alchymist
Nov 7, 2005 01:50 PM
