Brake Fluid Replacement
Old Feb 11, 2014 | 07:02 AM
BigDaddy_2's Avatar
BigDaddy_2
What is are you using when you replace your brake fluid?
Old Feb 11, 2014 | 07:55 AM
Hdslider's Avatar
Hdslider
What exactly are you wanting to no? A tool.or what kind of brake fluid?
Old Feb 11, 2014 | 08:28 AM
69cj's Avatar
69cj
Deleted due to brain fart.
Old Feb 11, 2014 | 10:07 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Use any DOT 3 fluid, or greater (DOT 4, or DOT 5 is fine too). Ensure when you replace it, you flush all the existing fluid out, and replace with just one brand/type of fluid, and if/when you top up the fluid in the future, you use the same brand/type of fluid.
Old Feb 11, 2014 | 10:14 AM
720Deere's Avatar
720Deere
Originally Posted by 69cj
Mercon V synthetic.
I need to hear more on this theory!
Old Feb 11, 2014 | 11:59 AM
69cj's Avatar
69cj
My BAD, I was thinking power steering. Thanks for waking me up. I shouldn't answer questions that early in the morning. The body is up but not the brain.
Old Feb 11, 2014 | 12:28 PM
720Deere's Avatar
720Deere
I wasn't trying to be a smartazz as you are generally a good source of information. I really thought I was going to get an education on how Mercon V is superior to brake fluid!
Old Feb 11, 2014 | 01:25 PM
69cj's Avatar
69cj
No offense taken. When I'm wrong or make an out of conscious statement I preferred being brought back to reality.
Old Feb 11, 2014 | 01:27 PM
Chad149's Avatar
Chad149
I flush my brakes every two years. Clean and lube caliper slides at this time as well. I use dot 4 but only because that's what we use here at the German shop I work at. Tool wise I have a vacuum bleeder that hooks up to the bleeder screw, makes easy work of it.
Old Feb 11, 2014 | 01:53 PM
BigF350's Avatar
BigF350
FTE Emeritus
A Vacuum bleeder is one of the best $20 you will spend.
tractoman
Aug 24, 2023 08:09 PM
UGA33
Nov 19, 2019 08:40 AM
aaronlockhart
Mar 27, 2009 04:45 PM
1975Ford
Oil & Lubrication
13
Jan 4, 2007 11:31 AM
