bought this truck with the 35's so i am guessing its a 4" lift. Trailer that is hooked to it is approx 7k enclosed, that we pull for our church. This is the first trailer I hooked to it, and admit that i should have used a WD hitch, but I really did not think it would sag that much. I would prefer airbags or timbrens but with the lift will they work properly?
Can you measure the rear blocks?? I bet they are stock f250 blocks, which should be around 2 inches tall, if so I think you won't have issues with bags or the timbrens.
Tires just happened to be going to the shop that day for the Jeep, they are not normally there.
I will measure the rear blocks after I snow blow today. Got a foot last night and its still coming down. I guess I assumed there was a lift on there since it had 35's I did not think they would fit stock, but i have been wrong plenty of times before.
Not sure on the tongue weight. I know when the trailers were set up by the church, they calculated everything to the oz. but there is not a way to rearrange it. Goes together like a puzzle. buying a travel trailer this weekend and still have to hook up my 18' car hauler with my Jeep on it to see how they do.
Any advise on Timbren vs airbags? or is that like asking Gas vs diesel?
No, both work well. I think air bags are the more recommended solution. I just do not want you to spend money where it isn't needed, hence the recommendation to check your tongue weight.
Ideally, on a bumper pull, you want 10% of the trailer weight carried on the tongue. With a 7000 pound trailer, you should have 700 pounds on the tongue. Based on your squat, it looks like you have a lot more than 700 pounds on the bumper. You might try going to a local RV shop and see if they have the scales to weight the trailer and tongue weight. Being a church trailer, you might get that done free of charge.
AFTER the trailer's tongue weight is confirmed to be 10-12% of the trailer weight airbags can be used to level the rear. I tow landscape trailers and an RV on occasion and what I don't know the weight of I take to the scales. Check out a small hydraulic weighing device from Sherman for direct tongue weights, or there are numerous ways to use a bathroom scale and levers to get tongue weights.
