Engine Cranking Issue
So process of elimination:
Solinoid - New
Battery Cables - New
Starter - New
The motor is a 351w that the previous owner said was fresh and after seeing the carbon build up on the back of the intake valves, I knew it was about as fresh as a camels a$$. BUT my goal was to get a few months out of it and rebuild or replace it anyway. When it is cold and it gets started, after it warms up it runs pretty dog gone good. It is as though the heat is swelling up the motor and it is locking down.
I will be looking forward to hearing your ideas on what could be causing this.
2) Check charging voltage at the battery terminals at fast idle. You should see something in excess of 14 volts. Your new battery may not be getting fully charged. Maybe throw a charger on it overnight and see if that helps.
2. Running a G3 alt. It is charging 14.5 volts at idle.
It sounds like you are charging and not overheating as Hio suggested.
I do not want to insult you but are you sure that all the connections to the new starter and cabling were well scuffed up and securely tightened? A small amount of resistance will kill you on the starting circuit.
But no, I found the out hard way while on a date and needed to get her home and get it started right away.
I had fender well headers then and new, I wasn't over heating the starter from them..
So, I got some ice water from a "car Hop" and poured in on the starter housing to cool it down the best I could for a few minutes, The tried the key an it starter 'Bingo' the next day replaced it the starter..
The brass shaft bushing were binding up when it got warm..
Also the newer vehicles use smaller battery cables so make sure your using the correct size cables.
orich
orich
I am going to do a test this morning. I am going to use a wrench on the crank shaft to get some idea of the resistance of turning it by hand. Then I am going to run it for 20 to 30 minutes shut it off and do that again to see if there is a difference. I suspect I will not like the result of this test.
If it isn't much different, I will douse the horny starter with ice cold water.
orich
Thanks all for your help! The issue was traced down to the starter. The crank had no more resistance warm than it did cold, all the connections checked out, voltage was good and last item was to check out the new starter I bought in September that I have used maybe a dozen times. We pulled it out and it wasn't centered in the nose cone. When I got it to O'Reily's it was straight? :hmm: Started pushing and shoving and it was all over the place. They pulled out another remanufactured unit that looked to be from the first redneck off road adventure (it was beat to he# and repainted) but the nose cone looked to be old school. Plug it in and it spins like a champ.
I will chalk all of this up to being my fault. I simple believe if it is new, its not worth reviewing. I will feel differently next time.
ORICH - I never though someones "hot date" in 1963 would be the answer to one of my mechanical quandaries. I owe you one frosti beverage sir.
. You get what you pay for.Sorry you had trouble Pinch.
