Carburetor question
Old Feb 8, 2014 | 03:14 PM
1979 300i6's Avatar
1979 300i6
Carburetor question
Be got a 1406 Edelbrock carburetor and I put it on my rebuilt 302, the problem is it goes wide open without pushing the throttle. So I pulled the carburetor and the gasket had a Tear in it and was wet with gas. Anyone have any thoughts on why its is going wide-open? And why the gasket was wet with gas?
Old Feb 8, 2014 | 03:31 PM
HIO Silver's Avatar
HIO Silver
Back to basics since the description is lacking....Got a carb return spring and is the linkage hooked up correctly?
Old Feb 8, 2014 | 09:04 PM
1979 300i6's Avatar
1979 300i6
yeah I checked that seems to be fine, I beginning to wonder if it's a intake leak? The engine starts up fine it just starts running really fast like 3000 rpm without touching the throttle.
Old Feb 9, 2014 | 07:21 AM
jim collins's Avatar
jim collins
Have somebody watch for linkage movement after starting and after you get your foot off of the accelerator pedal. That's to see if the throttle valve is opening all the way open on it's own . It sounds like a return spring is on wrong . Do you have a return spring on it to close the throttle valve up when you get off of the accelerator pedal ?
miihere24
26
May 26, 2013 08:25 PM
TJC
Oct 5, 2007 05:42 AM
Mr.Majestyk
Aug 5, 2004 11:48 PM
ceetwarrior
Jun 5, 2004 09:15 PM
FirstF150
Feb 11, 2002 08:45 PM
