Sponsored by: Auxito
Speedometer not working.
Old Feb 8, 2014 | 11:51 AM
slick8675309's Avatar
slick8675309
'98 F150. the speedometer isn't working, all other gages are. Where do I start ?
Old Feb 8, 2014 | 12:53 PM
projectSHO89's Avatar
projectSHO89
2WD or 4x4?
Any other symptoms?
Old Feb 8, 2014 | 12:56 PM
slick8675309
4x4, 4.6l motor, automatic
Old Feb 8, 2014 | 09:04 PM
clong's Avatar
clong
ABS light on? If so start with speed sensors. If ABS light is not on then most likely the gauge itself. If you have a good code reader you can check to see if the computer is reporting the speed.
Old Feb 9, 2014 | 07:05 AM
projectSHO89
The ABS system and its sensors have nothing to do with the speedometer on this model.
Repeating previous unanswered question: "Any other symptoms? "
Old Feb 9, 2014 | 07:15 AM
slick8675309
Sorry never noticed the other question. Nope just basically the speed o meter, odometer and tripmeter is not working. I seen in the manuel that there is a relay in the fuse panel for speedometer. Gonna check this first. I assummed that all the gages would be on the same circut. You know what they say about assumeing lol
Old Feb 9, 2014 | 04:03 PM
goodoleboy80's Avatar
goodoleboy80
Sounds like the speed sensor on transfercase is bad. I had the same problem several years ago on my '97 f150.
Old Feb 9, 2014 | 05:23 PM
projectSHO89
There is no relay in the fuse panel for the speedometer. The VSS is not on the transfer case for his truck, it's on the left rear of the transmission.
Does the cruise control (if equipped) work?
Old Feb 10, 2014 | 05:51 AM
slick8675309
never tried the cruise, if the speedometer isn't working then the cruise won't
Old Feb 10, 2014 | 05:53 AM
slick8675309
Sorry I got 2 issues confused. My interior lights don't come on when door is opened. The relay I seen is for that, not the speedometer. Trying to troubleshoot too many issues at once lol
Old Feb 10, 2014 | 07:07 AM
projectSHO89
Maybe, maybe not.
If the VSS is working but the cluster is defective, the cruise will still work correctly (assuming no other faults). A faulty VSS will take out both functions which is why I asked the specific question.
There is both a madness and a method to my questions.
Old Feb 10, 2014 | 07:14 AM
slick8675309
As much as I'm tempted to go check the cruise I'll have to hold off on that. It snowed here last night and using crusie on snow covered roads seems like a bad idea lol
Old Feb 10, 2014 | 07:16 AM
slick8675309
Oh, what are you referring by VSS anyway ?
Old Feb 10, 2014 | 01:10 PM
projectSHO89
That's the sensor that detects drive train rotational speed which is mathematically converted into ground speed.
Also, if the (automatic) transmission shifts correctly, that would usually mean the VSS is okay. If the VSS were out, the PCM wouldn't be able to properly schedule transmission shifting.
BackWoodsBomber
Mar 22, 2015 06:28 PM
Leo
Jul 28, 2010 09:14 PM
99strokun
Sep 25, 2007 09:43 PM
Rangerman255
1983 - 2012 Ranger & B-Series
Sep 18, 2003 07:17 PM
ringo5291
Electrical Systems/Wiring
Sep 9, 2002 11:25 PM
