GPR
Old Feb 7, 2014 | 06:19 PM
C350CREW's Avatar
C350CREW
GPR
My gpr died today so I thought I would share my findings. Bill was telling me that Tyler had purchased a relay for a snow plow to use on a dump trailer and then he put one on his truck. So I started searching and found this, 12v 150A continuous duty 300A rush relay for golf carts. On Amazon for 16.99, pt# 1114208. It is set up to mount on a fender, but I was able to use one of the oem bolts. Would have went under both, but the wires would not let it. I will find out in the morning if it works or not, but I dont see why it wouldnt. This was the heaviest duty one I could find and if it works on a golf cart, I figure it would last a looong time on the truck. Now I need to figure out how to wire in a switch so the gp's are only on when I want. Any one know which wire I should cut and send to the switch?
Old Feb 7, 2014 | 07:42 PM
ReBilld's Avatar
ReBilld
You can break either one of the small wires with a switch.
Old Feb 8, 2014 | 08:27 AM
C350CREW's Avatar
C350CREW
Thanks Bill, I will give that a try. Can always count on good info from you.
90pioneer
6.7L Power Stroke Diesel
Sep 28, 2018 04:32 PM
timmyboy76
Aug 31, 2018 08:23 PM
884x4broncoII
May 28, 2008 07:42 AM
Imaoleguy
Sep 23, 2005 02:44 PM
Uncle Jim
Feb 26, 2005 05:39 PM
