6.0 Top End Issue
Old Feb 6, 2014 | 09:26 PM
Z28camaro69's Avatar
Z28camaro69
6.0 Top End Issue
Hey guys, I am having an issue with my 2003 6.0 around 50mph. I've done a lot of searching but haven't found a solution.
The truck has 98,000, completely stock, and the engine light is not on.
It starts fine and runs fine at low speed and low rpms but when I try to accelerate over 50mph or go up hill it acts like its choked down with no power and blows black smoke but not a lot.
I have pulled the EGR valve, cleaned it, and replaced the O-rings. I also replace both fuel filters. These changes had no effect.
Any suggestions would be greatly appreciated.
Old Feb 6, 2014 | 09:35 PM
9228.bobcat's Avatar
9228.bobcat
I would check fuel pressure. Make sure it stays above 45lbs. Did you use oem filters?
Old Feb 6, 2014 | 09:43 PM
Money-Pit's Avatar
Money-Pit
Welcome aboard. Do you have a boost gauge? If so, what is your max boost?
Also check intercooler boots/connections for cracks/leaks
Old Feb 6, 2014 | 10:12 PM
Z28camaro69
Thanks, I will check that, yes I used OEM filters.
Old Feb 6, 2014 | 10:15 PM
Z28camaro69
No boost gauge, I did change the boot at the turbo because the old one had a rip under the clamp. I will check the rest of the connections this weekend. What is the best method to check for leaks, sound?
Old Feb 6, 2014 | 10:28 PM
KRDiesel's Avatar
KRDiesel
If you have black smoke and low power under load it is a issue with low boost.
This video will show you one way to look for a leak
Old Feb 6, 2014 | 10:40 PM
Z28camaro69
Ford Powerstroke 6.0 Liter Diesel F250 Charge Air Cooler Intercooler Leak Test - YouTube
Thanks, that's a good idea
Old Feb 9, 2014 | 02:17 PM
Z28camaro69
I performed the pressure test and found no leaks. I figured it would be a long shot but had Oreillys scan the truck and it pulled no codes. It still feels like I'm dragging an anchor going uphill.
Old Feb 9, 2014 | 02:35 PM
Money-Pit's Avatar
Money-Pit
Ya need to get a Scangauge or similiar so you can read boost and some other sensors so we can evaluate the problem better.
There are things that could be wrong but won't throw a code.
Old Feb 9, 2014 | 04:39 PM
Z28camaro69
I was considering getting AE, should I get it or just ScanguageII?
Old Feb 9, 2014 | 05:05 PM
Money-Pit's Avatar
Money-Pit
AE is the ultimate scantool and is much better than the Scangauge for diagnosis of these motors. The downside is....it's not one you want to use for daily monitoring since it is on a laptop.
Old Feb 9, 2014 | 09:37 PM
Z28camaro69
I'm also looking for a fuel pressure test gauge setup that has a hose long enough to get the gauge to the windshield, any suggestions?
Old Feb 9, 2014 | 10:30 PM
karlsdash's Avatar
karlsdash
Also check ICP readings, that sensor goes bad and does stupid things to your truck.
Old Feb 9, 2014 | 10:49 PM
73fan's Avatar
73fan
Those mechanical oil pressure gauges, they work great and may even come with a nice long hose. Mine did and all I needed was the adapter to fit the filter housing.
Old Feb 10, 2014 | 12:05 AM
Mr.Nobody's Avatar
Mr.Nobody
Was having this same type of issue. I had a faulty EBP sensor. Changed it out and I've tone about 100 miles and so far the issue has been resolved. ScanguageII or something similar would be helpfull for sure.
