6.0 Top End Issue
Old Feb 10, 2014 | 04:33 AM
Mcrafty1's Avatar
Mcrafty1
Originally Posted by KRDiesel
If you have black smoke and low power under load it is a issue with low boost.
This video will show you one way to look for a leak
Ford Powerstroke 6.0 Liter Diesel F250 Charge Air Cooler Intercooler Leak Test - YouTube
Good information on the CAC leak test but I wonder why Ron didn't mention the after market oil filter cap? it would be a good time to tell people about the dangers of using them. Just sayin' Also could these symptoms indicate a plugged catalytic converter?
Old Feb 10, 2014 | 05:16 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by Z28camaro69
I'm also looking for a fuel pressure test gauge setup that has a hose long enough to get the gauge to the windshield, any suggestions?
I would actually urge you to get a full time electric gauge for your truck and mount it in dash. It's cheap insurance for your injectors IMHO.
Old Feb 14, 2014 | 09:43 PM
Z28camaro69's Avatar
Z28camaro69
I got AutoEnginuity and connected to my truck tonight.
The diagnostic trouble code scan brought up the following codes;
P0603 Internal Control Module Keep Alive Memory Error
P1000 OBD Systems Readiness Test Not Complete
P2290 Injector Control Pressure Too Low
Engine Cold Idle ICP = 745 PSI
Engine Warm Idle ICP = 637 PSI
Engine Temp = 191.2
Oil Temp = 206.3
EBP stayed around 1.1 volts
Turbo Duty Cycle was 76% at idle and would drop around 50% at 30mph
FICM = 48V
Mass Air Flow = 4.0 to 4.7 lb/min at idle
Still no power going up hill.
Does this data give anyone any ideas or have suggestions on other things to check with AE?
Old Feb 14, 2014 | 11:22 PM
bismic's Avatar
bismic
P2290 is a running ICP code. Some likely causes are ICP sensor issues, an IPR issue, or even a weak HPOP.
Please post ICP, ICPV, ICP desired, IPR duty cycle , speed, and rpms when the problem starts.
Old Feb 15, 2014 | 09:37 PM
Z28camaro69
Readings from when problem starts
ICP = 671.89 PSI
ICPV = 0.92 V
ICPD = 3616.6 PSI
IPR Duty Cycle = 84.77
Speed = 31 MPH (Uphill)
RPM = 2849
I pulled the EBP sensor and tube today just for the heck of it, they both looked clean but I went ahead and cleaned them, no change with problem.
Old Feb 15, 2014 | 09:54 PM
bodywerks's Avatar
bodywerks
actual vs desired ICP is what you need to look into. Either a HPO leak or HPO pump looks to be the problem.
No codes though? seems like IPR would be approaching 100% to get you to the ICPD and be throwing a code for ICP out of range/too low.
what's your boost pressure when the problem starts?
Old Feb 15, 2014 | 10:49 PM
78fordman's Avatar
78fordman
Remove and clean the ipr and retest.
Sent from my leash using IB AutoGroup
Old Feb 15, 2014 | 11:00 PM
Z28camaro69
I'll have to get back to you on the boost pressure.
Something I did notice while going back through the test data is that up to 2000 rpm the ICP pressure was much higher and just slightly lower than desired, IPR ranged between 30-45%. Once I hit 2000 RPM the ICP dropped down to the 600PSI range and IPR jumped up to 84.77% and did not change.
Old Feb 15, 2014 | 11:22 PM
bodywerks's Avatar
bodywerks
that's just because of pulse frequency, I imagine. Since there is a restriction or loss of flow somewhere it becomes harder to maintain pressure as the flow demand(frequency) increases. I like 78ford's suggestion to check your IPR screen. If it's clogged it may pass just enough to get desired pressure under lower RPM but not higher RPM.
Old Feb 16, 2014 | 05:55 AM
bismic's Avatar
bismic
84.77% means that it is being commanded to close as much as possible. I would bet on it being an HPOP issue, but cleaning and/or replacing the IPR is a cheaper thing to try first.
Old Feb 16, 2014 | 06:54 AM
mustang_309's Avatar
mustang_309
ICP = 671.89 PSI
ICPV = 0.92 V
ICPD = 3616.6 PSI
RPM = 2849
What are ICPV's at KOEO? Being an 03' i would pull the ICP connector and look for the presence of oil.
Old Feb 16, 2014 | 08:56 AM
npccpartsman
I'd air test it and clean the IPR first too, but I'd bet on it being an HPOP problem also since it's only producing 670 psi.
Old Feb 16, 2014 | 05:55 PM
  #28
Z28camaro69
ICPV at KOEO = 0.18V
I have ordered the IPR socket and will check the screen. I also check the ICP for oil while I'm back there.
Old Feb 16, 2014 | 06:24 PM
  #29
bismic's Avatar
bismic
You will be looking for something inside the IPR that might be holding it open.
Old Feb 17, 2014 | 07:21 AM
  #30
dvldog13's Avatar
dvldog13
could be stiction issues?
