Just went out and checked. The lever moves as said above. The cable runs up the radiator frame and across the top of the radiator frame, the catch is in the center of the radiator frame. If the cable is frozen or broken you might be able to stick a coat hanger in the grill and open the catch.
The catch pivots at the bottom. It is shaped like a backwards 7. You will have to hook it and pull toward the passenger side. It looks like if you pull the bottom of the hood up as far as possible you might be able to get a wire in there through the grill and open the catch. Once you have hooked the catch let the hood go back down just a bit. That should make it easier to open the catch. Hope this helps.
