Problems
Old Feb 5, 2014 | 07:08 PM
Ericasands's Avatar
Ericasands
Problems
06 f550 6.0 diesel 135,000 miles truck runs good but when going on the interstate check guage comes on n engine temp goes all the way to red I pull ova turn truck off n just turn key to read temp n it's not running hot so start truck n go again n runs fine does it if u go ova 60 mph if u stay below 60 no problems changed thermostat n sensor any suggestions
Old Feb 5, 2014 | 07:40 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Good chance it's a clogging oil cooler. You need a device to check oil and coolant temp. Several smart phone apps, ScanGaugeII from autozone or online, or laptop software and OBDII adapter. Oil temp should stay within 15 degrees of coolant temp at 70mph cruse fully warmed up.
Several other possible problems coud cause this but oil cooler is most likely and except for checking coolant level is first place to start looking.
If you continue driving it the EGR cooler will start leaking. Steam/white smoke out tail pipe and possible serious/expensive engine damage follows quickly.
Old Feb 5, 2014 | 08:05 PM
Ericasands's Avatar
Ericasands
Thank u I will try that appreciate I will let u know thanks
Old Feb 5, 2014 | 08:06 PM
Ericasands's Avatar
Ericasands
Oil cooler can cause ya gauge to spike up but not really running hot
Old Feb 5, 2014 | 08:21 PM
bismic's Avatar
bismic
You might want to take a quick look at the condition of the coolant in your degas bottle (coolant reservoir).
Old Feb 5, 2014 | 08:23 PM
Money-Pit's Avatar
Money-Pit
The dash gauges are pretty worthless....
did it seem like the motor was actually hot when the water temp gauge showed hot? Do you hear your engine fan rev up like a jet when the gauge shows hot?
Old Feb 5, 2014 | 08:42 PM
Ericasands's Avatar
Ericasands
No coolant is fine and fan runs normal just my guages when I go ova 60 when I turn it off n turn bk on everything reads and runs fine
Old Feb 5, 2014 | 08:48 PM
bismic's Avatar
bismic
Sounds like a gauge panel going bad on you.
Old Feb 5, 2014 | 09:23 PM
DerbyPowerstroke's Avatar
DerbyPowerstroke
I assume you are on your way to your job as an English professor at the university?
Old Feb 5, 2014 | 09:33 PM
04badford's Avatar
04badford
I Think she misunderstood, the cooling fan kicks on at 215deg, not the big radiator fan , Rusty is right you need a way to monitor the values , I use the Scan Gauge II from Auto zone,and as Money pit and Bizmic said the dash gauge don't really tell all or it could be Instrument panel Issue. On the degus bottle the level should be at or just below Min line, any lower than this you take a risk of blowing the heads. Do you see any coolant dripping any where under the truck or on top side Valley of Engine. If the Oil cooler is plugging or plugged your Temps will Spike and then all hell will brake . need to get a monitor
Old Feb 5, 2014 | 09:46 PM
clevelandtundra's Avatar
clevelandtundra
lol ziiiing.
Old Feb 5, 2014 | 09:47 PM
olfordsnstone's Avatar
olfordsnstone
Bingo! Mine did something similar back while under warranty. It was determined at the dealership that I had a faulty instrument cluster. The Service Tech stated that there was a bad batch and I got one of them. He said that dust made its way into the cluster, causing the erroneous readings. I'd check with scangauge to see if readings are normal to rule in or out running hot or instrument cluster failure.
Old Feb 5, 2014 | 09:49 PM
clevelandtundra
Just to refresh, at or just below the min line after a overnight cold sit. After the engine has been up to operating temps an inch or so below the min line is acceptable. Is this correct?
Old Feb 5, 2014 | 09:53 PM
04badford's Avatar
04badford
Correct or could be an 1'' above at operating temp but never at MAX
JamesMcMn
Oct 17, 2016 10:47 PM
olfordsnstone
Aug 19, 2016 05:34 PM
mntruckguy
Jun 30, 2015 08:21 PM
armydude
Jul 4, 2012 01:05 PM
strokin83
May 24, 2012 05:24 PM
