1978 - 1996 Big Bronco
Tachometer fuse keeps blowing
Old Feb 5, 2014 | 09:17 AM
fordtrck302's Avatar
fordtrck302
84 Bronco 302
Recently with my electrical problems that I thought were fixed, I now have a new issue with the fuse for the tach, it keeps blowing. It seems to do fine once I replace it and the truck is just sitting there idling but once I actually start driving it blows.
This is a new problem and only started after I put in my wire going from the post on the alternator to the start solenoid. Without this wire the fuse panel in my truck had absolutely no power. I already have a post about that issue.
I know people say to try and isolate each individual component that the fuse goes to. This fuse works the Seat belt buzzer, warning indicator, Carb Circuts, Tachometer and Choke heater.
Any clue as to a good way to troubleshoot this problem?
Old Feb 22, 2015 | 01:24 PM
nikremt's Avatar
nikremt
I have the exact same problem on my 1984 F250. Sometimes I can drive up to a few weeks before it blows again. Lately it has been almost every day.
Have you had any success?
I just disconnected the seat belt warning system and buzzer to see if the short is somehow related to that. I'll keep you posted what I find out.
Old Feb 23, 2015 | 11:30 AM
fordtrck302
I am almost certain mine is the circuit paper on the back side of the gauges. I have had to do a repair when I first bought the truck. The fuse seems to blow when I turn on the headlights or turn the **** to dim/brighten the display. If it doesn't blow the fuse than when I do those movements with the headlight switch it makes the tach jump all over the place
Old Feb 23, 2015 | 12:49 PM
nikremt's Avatar
nikremt
Interesting, I see no such correlation with my issue.
Old Apr 9, 2019 | 04:53 AM
nikremt's Avatar
nikremt
Fixed tach fuse keeps blowing
For me, after many things, this was solved when I replaced the ignition control module. Wanted to post this for others just in case this gave you as much headache as me. Now after 4 years, I haven’t had a blown fuse.
Old Apr 10, 2019 | 01:29 PM
AbandonedBronco's Avatar
AbandonedBronco
Thanks for the update on this. Ugh, I can imagine the frustration after dealing with it for years.
I would never have guessed it was the ICM.
Good info!
King0581
27
Jul 20, 2019 08:57 PM
Magister
1983 - 2012 Ranger & B-Series
Feb 4, 2017 03:32 AM
fbh31118
Electrical Systems/Wiring
Sep 15, 2011 05:37 AM
ncguy23
Jul 27, 2007 03:33 PM
JICASE
Nov 14, 2005 11:01 AM
