Help with front suspension
Old Oct 25, 2013 | 04:41 PM
capelo's Avatar
capelo
Question Help with front suspension
hi i need to know what the correct mounting position, which of the two posicones is correct? thank you very much
Old Oct 25, 2013 | 05:39 PM
das54's Avatar
das54
Hey, haven't heard from you in a while. It's great to have you back asking questions. Sorry that I can't help you with your question but I'm sure someone will be along soon enough.
Old Oct 25, 2013 | 07:39 PM
wallster's Avatar
wallster
I'm not positive about the front leaf springs but i had this very same question answered for the rear springs on my last '51 and I don't think it will matter (if it's the front or rear springs). Here's the post (see link below), hope it helps.
Wally
https://www.ford-trucks.com/forums/1...-thoughts.html
Old Oct 25, 2013 | 08:05 PM
seaves46's Avatar
seaves46
The one you have fitted is the correct original way , the other spring has it's eyes reversed and will drop your truck a bit .
Old Oct 26, 2013 | 11:23 AM
53OlderThanMe's Avatar
53OlderThanMe
Is that spring only reverse eye on one end? Never seen that before should lower you a little bit. I would put the reverse eye on the shackle end to prevent any chance of binding. Important thing is obviously mount both sides the same.
Old Oct 26, 2013 | 02:17 PM
capelo's Avatar
capelo
thank you all for your comments, these springs are lowering speedway 3 "Posies Super Slide Springs D154F 1953-56 Ford Pickup Drop Front Springs - Speedway Motors, America's Oldest Speed Shop
install difference of one form to another is important because it significantly changes the axis inclination as well as the center inside the fenders ..... not to do
Old Oct 27, 2013 | 05:21 PM
capelo's Avatar
capelo
I saw this picture, but do not understand why this well done
Maltman
Dec 2, 2018 06:21 PM
df85732
Feb 27, 2017 07:38 AM
chriscris
Aug 8, 2012 07:49 AM
polarspeed
15
Aug 3, 2011 08:04 AM
