Instrument panel lamp out, all exterior lamps out - '91 F250 XLT
I have a 1991 F250 XLT Lariat 7.3l IDI. The instrument panel lamp just went out, as did all the running lights. The headlights work, as do the turning signals and the brake lights. But no running lights. There is a 15amp fuse in the fuse box that is precisely for the Instrument Illumination and the exterior lamps, but that fuse looks fine. I replaced it with a new one just to be sure and that doesn't fix the problem. What else could it be because it seems like it has be that circuit but the fuse isn't blown? The contacts inside the fuse box look ok from a quick visual inspection.
Thanks for any advice.
Let's see. The **** and shaft comes out by pushing a little button on the front of the switch. After that, I think it's just one nut holding it in. It's pretty self-explanatory once you get started.
