Dashboard/instrument lights dead, help?
Old May 31, 2009 | 05:28 PM
cadunkle's Avatar
cadunkle
I just completed a 460 swap in my '86 F-250 Supercab and was installing my gauges in the factory instrument panel bezel. Got them in and tapped gauge lights to the dash light terminal of the headlight switch. Now no dash lights at all, and factory gauges don't work. I have 12v at fuse #4 (instrument lights, and other lighting). Any ideas?
Old May 31, 2009 | 07:25 PM
dustybumpers's Avatar
dustybumpers
there's a 5 amp fuse in the fuse box, it is only hot when the lights are on. check that and it may be your problem. if not you have to take the headlight switch out, and look at the harness where it pliugs in. they get hot, and usually the dash lights are 1st to go.
Old May 31, 2009 | 09:59 PM
ctubutis's Avatar
ctubutis
Given that this problem began when you messed with the wiring, methinks either you blew
one or more fuses (as was mentioned) and/or you're tapped into the wrong circuit. What
color was the wire you tapped into? It should be light blue/red stripe.
Old Dec 26, 2010 | 06:42 PM
JimNQ's Avatar
JimNQ
My instrument panel lights failed a little while ago. I checked out fuse 13 and it appeared OK so checked the fuse box with the multimeter. When I stuck the probe into the fuse holder, the metal tags that contact the fuse just fell out as they had corroded through! I bought an accessory fuse holder, removed the wires from the standard box, and hooked them through the new holder and I have dash lights once again. They're still really dim, so I'll pull the instrument panel out and take the covers off the bulbs.
Jim
Old Dec 27, 2010 | 12:56 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I would try to get some wire end terminals for your fuse panel. Ford used these same fuse panels for a lot of years, so they should have the terminals you need to fix the problem to where it looks like it never happend.
Old Dec 27, 2010 | 03:43 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Bad or missing ground?
