Bad PSOM?
Old Feb 3, 2014 | 09:56 PM
mots42's Avatar
mots42
Bad PSOM?
97 f250 5.8. my speedo isn't working at all, abs light is on a flashing o/d. I have replaced the abs sensor twice one from autzone and now one from napa. I know read the codes... my uncle works in a transmission shop, just haven't been able to get it in. we had extremely cold weather here, -5 and just before the cold all these above symptoms happened. Once it warmed up, I cleaned the sensor and o/d light was not flashing trans shifted good, but speedo was jumping. Came out the next day and all my problems came back. so im thinking the PSOM? im going to get a new cluster, but was wondering if a bad cluster would cause the flashing o/d and abs? im sure its been covered, im just finding a lot of symptoms about the diesels. thanks for any help.
Old Feb 4, 2014 | 08:00 AM
subford's Avatar
subford
The sensor on the rear axle almost never goes bad but it gets changed a lot.
You say it worked after you cleaned it and now it does not. That would tell me you have a problem in the rear end or the sensor plug.
I would put the sensor back in that came with the truck and pull the cover off the rear end and check it out. Sounds like you have shavings in the oil.
You can unplug the PSOM and see if the abs light goes out as you drive, if it does then the PSOM is shorting the AC signal from the rear axle to ground.
OR
You can unplug the RABS module and see if the speedometer starts working and the o/d light does not flash.
This may not tell you much as if the signal is week and you unplug one module the other may work for a while.
Old Feb 4, 2014 | 03:50 PM
mots42's Avatar
mots42
ok, bought a used cluster from the salvage yard, speedo will actually read speed, no flashing o/d but speedo bounces a little and abs light is still on? what else can I check?
Old Feb 5, 2014 | 07:54 AM
rla2005's Avatar
rla2005
I still suggest you check for codes from the PCM. No sense throwing more parts at until you see if there are any stored codes.
The RABS light also means that system is sensing something wrong. Good reading in this thread from another forum: Brake and Rear ABS lights on - FSB Forums
GrumpyTroy
Nov 15, 2015 01:44 PM
cabloom300
Jun 26, 2012 04:18 PM
math427
Nov 10, 2008 07:38 AM
cassenbl
Sep 1, 2008 06:06 PM
RoushFan00
1983 - 2012 Ranger & B-Series
Oct 7, 2003 05:28 PM
