Sponsored by: Real Truck
Help, no speedo/odo
Old Jun 25, 2012 | 10:35 PM
cabloom300's Avatar
cabloom300
Help, no speedo/odo
Ive been dealing with this issue for awhile, first it was off and on working, now the ABS light stays on all the time and the speedo/odometer will not work. I replaced the ABS sensor in the rear and it worked for about 50 miles and now its back to the same. Anyone have any ideas? Thanks
Old Jun 25, 2012 | 11:38 PM
jh818's Avatar
jh818
There is a Vehicle Speed Sensor on top of the rear differential that works your speedometer. Maybe a bad connection?
Old Jun 26, 2012 | 12:02 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I also say check the VSS (On the rear diff)
Old Jun 26, 2012 | 04:18 PM
cabloom300's Avatar
cabloom300
The connection seems to be ok. I imagine if it was off and on that the sensor would come off and on, which it used to do but now it doesnt work at all and the ABS light is always on. Would pulling the codes and deleting them help? I may try that now.
BackWoodsBomber
Mar 22, 2015 06:28 PM
calf roper
Jan 10, 2009 10:29 AM
SteveO.
Aug 26, 2008 10:05 AM
XmyfirstsuperdutyX
Jun 28, 2004 07:56 PM
merritdc
Electrical Systems/Wiring
Jun 4, 2003 07:54 PM
