Brake pedal stutter?
Old Feb 2, 2014 | 04:55 PM
Redfridge's Avatar
Redfridge
Hi friends
Well my brake pedal is stuttering while pushing down.
Have an abs light. Pulled codes. Left front sensor issue.
Would this cause my pedal stutter?
Removed #10 fuse in cabin and it stopped. So did the speedo.
So thinking before I dive into a master cylinder or brake booster....replace sensor?
1999 Eddie Bauer 5.0. AWD
So do I get the 4wd sensor or the 2wd?
Hey thanks for any input.
Old Feb 2, 2014 | 05:46 PM
dustybumpers's Avatar
dustybumpers
Could be the star inside the rotor it reads is too rusty. Be sure to clean it when you put the new sensor in.
Get the 4 wd sensor
Old Feb 3, 2014 | 10:33 PM
Mikeman's Avatar
Mikeman
Before you go out and buy the sensor, check the wheel bearings. Jack up the front end and push/pull the wheel. If there's play, isolate it to the bearings or ball joints (or both). Or, just remove the sensor from the bearing assembly and check for signs of contact. It seems like these bearing assemblies don't last long, or at least not as long as the bearings on my '91 Ranger. Neither do the ball joints.
If the bearings are worn enough, the speed sensor ring gear can contact the sensor. If you put a new sensor in a worn/loose bearing assembly, the sensor will be damaged. The only way to fix this is with a new bearing assembly (which includes the sensor).
Old Feb 4, 2014 | 12:59 AM
Redfridge's Avatar
Redfridge
So wait.
I can purchase a sensor if needed for $100 or a full wheel hub assembly for $80 that includes the hub and a sensor?
Wtf?
Old Feb 4, 2014 | 10:05 PM
Mikeman's Avatar
Mikeman
I got my bearing assembly (including sensor) for about $100 from Rock Auto. It was a Timken, which is what was in there originally. You can certainly spend more than that, but I wouldn't spend less on a questionable brand.
Speed sensors start at about $10 and go up from there depending on who makes it.
It would take about 10 minutes to change the sensor. The bearing assembly would take an hour or two depending on how quickly you work and what else you do while you're in there.
Old Feb 5, 2014 | 06:22 AM
shorod's Avatar
shorod
Text deleted due to inaccurate information.
meborder
Nov 19, 2015 05:36 PM
Trouble1263
25
Apr 20, 2014 09:21 AM
srteach
Nov 17, 2012 10:13 AM
agryphon
1983 - 2012 Ranger & B-Series
Oct 16, 2006 07:52 PM
outlaw75
Aug 13, 2004 01:57 PM
