Broke ABS sensor while replacing needle bearing! Anyone have an extra?
Long title but it says it all. I was going to shoot some grease in the hole per Springer Pop's threads, while trying to remove it snapped at the o-ring. Anyone have an extra? Cheapest I can find is $140.00.That's half the price of a new hub assembly WITH a new sensor.. I need a connector like this::
[IMG]<a href="http://s627.photobucket.com/albums/tt360/trouble1263/?action=view&current=ABS.jpg" target="_blank"><img src="http://i627.photobucket.com/albums/tt360/trouble1263/ABS.jpg" border="0" alt="Photobucket"></a>[/IMG]
Reason: Wrong url for image
I have an extra sensor, but can you repost the pic so I know its the right one? It has the o rind and worked when it was removed from a bad hub. Give me your address in a PM and I will send it your way no cost!
Hey Trouble, where did the end of the sensor go? Reason I ask is I have a strange sound from a hub, maybe similar to a tumbling ABS sensor head??? Hmmm.....
The end is still stuck in the hub..I'll try an EZ out when I get after it!
