performance lpop
Old Feb 1, 2014 | 04:41 PM
plumb-evil's Avatar
plumb-evil
performance lpop
Hey guys, ive got an 03 6.0. Launched another lpop today. 5th one in the life of the truck. Its a 6spd and I turn the crap out of it. Where is a good place to get a performace one? 160k and hoping for 300...
Old Feb 1, 2014 | 04:55 PM
Maxium4x4's Avatar
Maxium4x4
I have an 03 on my original lower pump, used to turn 4200 .... so what is ...going on?
Old Feb 1, 2014 | 05:04 PM
BLADE35's Avatar
BLADE35
Post a Pic of these LPOP Gears
I assume you have something else going on But the result is LPOP Failure
Old Feb 1, 2014 | 05:07 PM
Maxium4x4's Avatar
Maxium4x4
Are you stuffing new gears back in and moving on or did you replace the front engine cover each time? Fluid damper by any chance? Just throwing that out there.
Old Feb 1, 2014 | 05:22 PM
plumb-evil's Avatar
plumb-evil
The inner gear breaks in 4 pieces and is wedged into the outer gear. Changed the first one at 30k. Can't imagine whats going on otherwise. Good oil, good pressure only happens on a hard 2nd/3rd shift.... ive got pics but not sure how to post em. And yes I have changed the front cover before. Last couple times just tossed gears in it.
Old Feb 1, 2014 | 05:24 PM
plumb-evil's Avatar
plumb-evil
Perhaps I should invest in a torsional dampner?
Old Feb 1, 2014 | 05:30 PM
Maxium4x4's Avatar
Maxium4x4
Normally, they do not just up and break. You said you turn the crap out of it... what RPM's are you running?
Old Feb 1, 2014 | 05:35 PM
bismic's Avatar
bismic
Just curious - do you ever use aftermarket oil filters?
Reason I am asking is I wonder if you can somewhat "starve" the HPOP for oil by allowing some of the oil flow to drain back to the crankcase. Just trying to think out-loud what might put extra stress on the pump.
Old Feb 1, 2014 | 05:36 PM
plumb-evil's Avatar
plumb-evil
Today was about 4100 when it broke, I was loaded with s 10000 lb tractor and schooling a dmax.... of course my celebration was short lived. There are times she gets some "hot suppers" though haha
Old Feb 1, 2014 | 05:41 PM
plumb-evil's Avatar
plumb-evil
Yes Bismic........... guilty as charged. And I know better!
Maxium4x4's Avatar
Maxium4x4
Got a few things, you are consistent, so without much explanation. Trash will break the gear, crank movement, operator error. Pick one. Hate to be blunt but...
Old Feb 1, 2014 | 05:42 PM
npccpartsman's Avatar
npccpartsman
You have crank/bearing issues
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The OP is grenading LPOPs not HPOPs
Josh
Old Feb 1, 2014 | 05:43 PM
Money-Pit's Avatar
Money-Pit
Nevermind.....
Old Feb 1, 2014 | 05:44 PM
plumb-evil's Avatar
plumb-evil
I was assuming there were performance pumps out there. Looked at RIVER CITY, no dice... oil change and motorcraft filters?...
