Sponsored by: Auxito
Engine Light - 2 Blinks
Old Nov 11, 2003 | 06:56 PM
CMMerscher's Avatar
CMMerscher
'97 F-150 4.2L V-6. I was wondering if anyone knew the codes for the OBD when the check engine light comes on. Mine is on and when i turn the key a few times it turns on, turns off, then turns on steady. I do not know if this would be considered as 2 blinks or 1 blink. If anyone knows what it means tell me. It is running a bit on the rough side also. Thanks
Old Nov 11, 2003 | 07:17 PM
bosshoss's Avatar
bosshoss
I think it should be a steady light with OBD. You will need someone to read the codes with a scan tool. I dont know if you can get the codes anyother way. Racerguy might be able to clue you in on this. I think most auto parts stores now offer free checks. I would give some a call and see. Good luck.
Old Nov 11, 2003 | 09:09 PM
Racerguy's Avatar
Racerguy
You're right Dave. On a vehicle with OBD2 the only way to retrieve trouble codes is with a scan tool.
Christopher Roche
2004 - 2008 F150
Nov 26, 2013 05:14 PM
cabloom300
Jan 13, 2011 01:48 PM
gramps2plus1
1997 - 2003 F150
Mar 22, 2007 02:06 AM
walkerrim
Electrical Systems/Wiring
Jun 1, 2005 09:55 PM
CMMerscher
Sep 27, 2003 09:31 PM
