Need a part
Old Feb 1, 2014 | 12:21 PM
AtomicNo13's Avatar
AtomicNo13
Need a part
Realizing I could order online I thought I'd appeal to a brother x owner first.
I need a pair of OEM rear sway bar mounting brackets.
Ford part number e5tz 5b498 OK
These mount directly to the diff/axle using u bolts. Kind of flat on one side and curved on the other matching the curve of the axle tube.
Also looking for the u bolts to go along.
Anyone have a pair from a donor x or other super duty?
Old Feb 1, 2014 | 07:37 PM
Larry Grimes's Avatar
Larry Grimes
Rear swaybar
My advice to you is install a new hellwig.It is a much better system than stock and a lot beefier .I removed the stock one and thew it away.I could not belive how much better it was.
Last edited by Larry Grimes; Feb 1, 2014 at 07:41 PM. Reason: spelled swaybar wrong.
Old Feb 1, 2014 | 08:18 PM
jayjjcc's Avatar
jayjjcc
You actually just threw it away? You also misspelled believe btw
Old Feb 1, 2014 | 10:17 PM
Bently_Coop's Avatar
Bently_Coop
You can always order from either tousley or horizon ford. Otherwise check a local wrecking yard.
Old Feb 1, 2014 | 11:16 PM
kornfanjoe's Avatar
kornfanjoe
The superduty has a heavier duty *130mm* rear sway bar not exactly sure of the number but I know it's beefier. I want to know if it's stronger than hellwig or not, but a wrecker would have more of them than an excursion
Old Feb 2, 2014 | 08:21 PM
jpr38057's Avatar
jpr38057
Fyi, not sure where you got that part # but it's not correct.
HaydenFryGuy
Feb 7, 2022 12:17 PM
MTurner2003
Offroad & 4x4
25
Jun 28, 2006 12:12 PM
f_pumillo
1983 - 2012 Ranger & B-Series
Dec 12, 2003 03:14 AM
c4xfire
Jul 5, 2003 11:03 AM
