Battery or starter 2000 x
Old Feb 1, 2014 | 12:10 PM
Skull buster's Avatar
Skull buster
So starter clicks does not turn over battery tested was 12.2v put the charger on it charge red to 14v still clicks but noticed when I turn the key all the way forward the volts drop to 10.9volts what u guys think starter or battery? Just bought it lastnite drove home and this morning doesn't even turnover
Old Feb 1, 2014 | 06:02 PM
sccamper's Avatar
sccamper
Sounds like starter. Rap on the starter with a hammer a few times while someone trys to start.
Old Feb 1, 2014 | 06:36 PM
Skull buster
Yea I put a new battery in and the cables look good and hit the starter and it still clicks
Old Feb 2, 2014 | 10:24 AM
sccamper's Avatar
sccamper
Make sure you have a good ground on the neg cable. Use a voltmeter and check to make sure you have battery voltage on the big cable at the starter, then the small cable with the key in the start position. If you have battery voltage on both, its time for a starter.
Old Feb 5, 2014 | 05:09 PM
Skull buster
It was the starter the big x is up and running thanks to all
Troy conrad
Jun 23, 2019 11:09 PM
joekacker
Nov 9, 2012 08:03 AM
2pazr
Feb 19, 2009 02:09 PM
rosa70
Oct 5, 2004 11:09 AM
jln_Wasabi
Electrical Systems/Wiring
Mar 3, 2004 10:36 PM
