Repainting grille
Old Feb 1, 2014 | 10:49 AM
Az_Ray's Avatar
Az_Ray
Repainting grille
Does anyone have any expirience doing this. I have a line on a black one for cheap, but would like to color match to the X. TIA
Old Feb 1, 2014 | 12:04 PM
Tuquala's Avatar
Tuquala
If you are talking aboot painting the whole grille, chrome and all, it won't stand up to rocks, etc in the chromed area. I repainted a Suburban grille to match aboot 8 yrs ago, and there numerous small shiny spots showing, not too noticeable except up close, but they will chip.
I just recently painted my Ex grille inserts black and it looks pretty good, better than the XLT silver!! Hoping it will stand up well over the next few yrs.
Old Feb 1, 2014 | 12:15 PM
Az_Ray's Avatar
Az_Ray
The one I'm looking at is a black factory one. Not chrome then painted black.
Old Feb 1, 2014 | 01:46 PM
mecdac's Avatar
mecdac
Thumbs up Grill Paint
Google Microfinish and get the paint in any quantity you wish.
Buy primer in the same range (gray or blue for your EX)
Clearcoat the finish
If you buy the rattle cans get one primer, two color and one clear
Two primer coats.
Four light coats (color) are better than two heavy coats
Three Clear coats
The honey comb grid section should be easily removed from the main outer section (frame).
The Blue Oval should also come out, less to mask.
Prime, Paint, Clear, Dry, Cure.
Four screws on top, 2-4 clips along the bottom R&R of the grill is two minutes.
Re-assemble the grill attach grill to EX.
Old Feb 1, 2014 | 01:52 PM
Az_Ray's Avatar
Az_Ray
Any tips if I want to paint the inserts??
Or just use same process
Old Feb 1, 2014 | 02:03 PM
mecdac's Avatar
mecdac
You will definitely need more paint a lot more, most will be waste.
I would remove them and paint them separately even if the same color.
Hang them on a wire and flip the ends between coats, the honey comb will need to have paint directed at it in different angles for adequate coverage.
If you paint over a seam that moves and flexes (like our grills) it will look horrible. It will crack at the seam and start to peel.
Hopefully Snowseeker can chime in with some advice he is probably a better painter than I am.
Old Feb 1, 2014 | 02:12 PM
nmclella's Avatar
nmclella
The inserts would be such a pain I would think.
90% of the paint would just go through while trying to spray it??
Old Feb 1, 2014 | 02:14 PM
mecdac's Avatar
mecdac
Thumbs up
That is why I said "a lot more paint".
Old Feb 1, 2014 | 04:23 PM
High Cetane's Avatar
High Cetane
Just another opinion from the cheap seats.
I'd suggest refraining from a "rattle can" top coats & primers.
A respectable finish calls for quality prep & materials.
I would also not suggest a clearcoat finish.
Consider an Acrylic Enamel w/ Gloss Hardener added as the most cost effective approach. Some shops will sell a pint, but I'd buy the quart just to have in case something else needs color.
I've shot many w/ Imron, and with proper prep (yes, even on plastic chrome) adhesion is never an issue, and chips dont happen.
This latest I did in Black Awlgrip (over chrome), and I can assure you, the rocks will break before the paint does.
Both reflectivity & depth are very good, and are far superior results that even the most accomplished rattle can operator will achieve.
Clean it (*wax & grease remover), scuff it w/ 220 or finer, prime it, scuff it w/ 4-600, clean again & tack, hang it securely. Apply 3) light coats 20 min apart. Use proper reducer for the temp, wear your respirator, and clean your weapon so you cannot tell what color came out of it.
Thats my .02 while on pain meds-
Old Feb 1, 2014 | 04:42 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I painted a XL painted grill to match my Ex also...i LOVE the look.
Old Feb 1, 2014 | 06:41 PM
Az_Ray's Avatar
Az_Ray
So should I leave it black.
Old Feb 1, 2014 | 06:46 PM
hanklin's Avatar
hanklin
I just re-painted my grille black recently from tan(ish) and it looked so much better and crisp, imo New color didnt look far off of original color
Old Feb 1, 2014 | 08:36 PM
Vince79vette's Avatar
Vince79vette
I just did mine. Mine turned that gray color so i used trim black and re did it so it matches the other trim. Trim black is the bees knees. I use it on all my cars and ppl always ask how I re finished my trim
chaser1602
Oct 11, 2010 08:02 PM
rlh68050
Nov 1, 2005 08:48 AM
dtupac
2004 - 2008 F150
Feb 3, 2005 12:51 AM
Toreador
2004 - 2008 F150
24
Oct 29, 2004 12:35 AM
chevey hater77
Jul 30, 2004 03:36 PM
