MSD distributor won't install
Old Jan 31, 2014 | 05:37 PM
48 Steel's Avatar
48 Steel
I've tried just about everything and I can't get the distributor to fully seat it's short by about 3/4". I've got a MSD distributor and I used the shaft off of my old original distributor to help line up the oil pump shaft with the dizzy. I have spent about 3 hours and no results. I contacted MSD and even sent pictures. The motor is out of the vehicle and so I am cranking it by hand. My final plan is to pull the pan and the oil pump, install the distributor then align the oil pump shaft into the distributor. Will this work?
_____________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"Happiness - 3 pedals and a 5 speed"
Old Feb 1, 2014 | 11:50 AM
Moe Craig's Avatar
Moe Craig
Sorry to hear the problem your having... Subscribing to find out what you find out!
Old Feb 1, 2014 | 05:32 PM
TMI's Avatar
TMI
Try installing the distributor without the shaft, then you may be able to isolate the problem.
Old Feb 1, 2014 | 05:54 PM
48 Steel's Avatar
48 Steel
Thanks for the advise. I will drop the pan, pull the oil pump and shaft then install the distributor. If it seats then I will secure it on top and re-install the oil pump shaft and oil pump.
_________________________________________
" Keep you're wheels between the ditches and your have off other peoples bi----e's"
Old Feb 4, 2014 | 03:07 PM
beartracks's Avatar
beartracks
Wait! Dizzies are notoriously hard to seat on these engines. The drive shaft lays against the side of the tunnel and doesn't go in the dizzy. I've used grease in the past to prop up the shaft. Also turning the shaft a little may help.
By the way. Really nice looking engine.
lalberts
Dec 4, 2016 10:30 PM
annaleigh
Apr 23, 2015 03:14 PM
Roy C
Dec 15, 2009 08:03 PM
MufassaMaxx
Nov 15, 2002 08:17 AM
oft
Mar 17, 2001 04:21 PM
