help with column removal,
Old Jan 30, 2014 | 10:11 PM
joekacker's Avatar
joekacker
My column went to hell, igntion broke and the metal rod had to be pushed with needle.nose pliers, so i have a new used column. My old column is.all lose and.ready to come out, but i cant get the shift linkage or whatever it is un hooked under the hood. Its like a solid metal thing pressed in a hole with rubber.around.it, any tricks to remove this? Ive been cutting the rubber, tried. Hammer, . My other column somehow was removed without any sign of damage to the piece .
Old Jan 31, 2014 | 09:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
use a large screwdriver or pinchbar to pry it out. it is a tight fit.
Old Jan 31, 2014 | 10:55 AM
joey2fords's Avatar
joey2fords
x2 ...mine was VERY tight.
Old Jan 31, 2014 | 01:49 PM
DBGrif91's Avatar
DBGrif91
Also, it may help if you TAP on it - with a brass hammer if available - because sometimes that can help break loose rust that's helping hold it together. I'm not concerned about damage to your old steering column, just the related components that you need to keep.
moroza
Jun 27, 2019 03:43 PM
hotrod351
Jul 25, 2016 03:07 PM
MissKady
Nov 28, 2009 06:19 PM
divermo
Nov 4, 2007 09:00 AM
Headman
Aug 26, 2004 09:00 AM
