IPR ICP
Old Jan 29, 2014 | 10:44 PM
skiscoot's Avatar
skiscoot
IPR ICP
I changed my IPR valve in my 2000 7.3 but sometimes at stop signs or stop lights the truck will die it will not start but if I open hood and disconnect the wire from IPR and reconnect it the truck will start right up. Is this a bad ICP?
Old Jan 30, 2014 | 01:07 AM
Yahiko's Avatar
Yahiko
Almost sounds like wire chafing. Have you inspected the plug and wires going back
into the harness for any damage or oil?
The reason I say try this is the cost is not that high vs a new IPR.
Sean
Old Jan 30, 2014 | 06:47 AM
Tom's Avatar
Tom
Hi skiscoot, welcome to FTE!
I'm going to send this one down to the 7.3L Powerstroke forum.
Old Jan 30, 2014 | 07:11 AM
Tugly's Avatar
Tugly
Not to pick nits... but you are disconnecting the ICP to get the truck running. I mention that for the readers, not to pick on you. You did good by way of troubleshooting, this sounds like a bad ICP... a lot of them are failing right about now.
Old Jan 30, 2014 | 12:56 PM
jhobbs26's Avatar
jhobbs26
Can the ICP fail and still be dry under the plug?
Old Jan 30, 2014 | 01:09 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I am very confused how you determined this ^^....
The OP said he replaced the IPR and then when the truck dies he removes and then replaces the plug and then the truck starts. To me this sounds like a possible wire harness problem with the IPR wiring like Yahiko is suggesting.
Old Jan 30, 2014 | 01:47 PM
t.scottNDU's Avatar
t.scottNDU
OP-
You should take a good look at the harness itself as mentioned above. Recently I was having a wondering idle, and low ICP at times... Intermittent I would say. I also had an instance where the truck died as I was zip tying some wires around the fuel bowl. I was led to replace the IPR, which I did. While I was changing it I noticed the harness was in rough shape... The wires were loose and the harness was brittle and old. I plugged it back in and ordered a new harness from DieselORings.
When the new harness came in I went to change it out and took a real good look. I noticed the wires had been contacting each other and it appears that it melted all the plastic around where they go into the plug. I spliced a new harness in and problem solved.
Old Jan 30, 2014 | 01:59 PM
Tugly's Avatar
Tugly
It's easy to explain... I'm an idiot. I failed to see the words "and reconnect it". In my OBDII-dazed head, it read something like "but if I open hood and disconnect the wire from IPR the truck will start right up". Apologies to skiscoot
Old Jan 30, 2014 | 04:49 PM
t.scottNDU's Avatar
t.scottNDU
As did I. Or I would've replied with my story the first time I read the thread. Seemed like you had a pretty good handle on it...
willbd
Jan 7, 2018 06:51 PM
TxFord0207
Sep 19, 2012 06:17 PM
RKern
Aug 8, 2012 10:55 AM
woody1967
Jun 20, 2012 09:19 PM
StrokedRanchero
May 11, 2006 09:52 AM
