eng cuts out
Usually cutting out like that is from a bad wire that is shorting out. The IPR connector wire is a good candidate to look at. You will need to start wiggling the wires as the truck is running. If you hear or feel a stumble, start looking more closely.
Another good spot to look at is the drivers side valve cover area. The wire harness to the engine tends to wear on the valve cover.
kyle j
18
06-02-2016 12:42 PM
1smokybear
05-25-2012 10:06 AM
sosuok
06-26-2009 06:40 AM
