summit racing carbs
Old Jan 28, 2014 | 09:54 PM
1999stroke's Avatar
1999stroke
summit racing carbs
hey guys was wondering if anyone has run a summit racing carb on any of there projects have always run holley's but the summit has a little bit better of a price any info would be appreciated
Old Jan 28, 2014 | 10:01 PM
HIO Silver's Avatar
HIO Silver
Yuuup.. I picked one up for $235 a couple of years ago. Ran well on my 65 'Stang before switching to an Autolite 4100. I highly recommend Summit's carb... it's a Holley clone. Go for it.
Old Jan 29, 2014 | 11:03 AM
bmuhlbach's Avatar
bmuhlbach
I bought a Holley 600 because I wasn't sure if I did it again I would have bought the Summit. Cheaper and dual feed.
Old Jan 29, 2014 | 12:27 PM
jim collins's Avatar
jim collins
What is the CFM on the Summit carb , 600 ?
Old Jan 29, 2014 | 01:44 PM
HIO Silver's Avatar
HIO Silver
your choice of 600 or 750 cfm
Old Jan 29, 2014 | 04:13 PM
1999stroke's Avatar
1999stroke
how big should I go on my 460
Old Jan 29, 2014 | 05:38 PM
JEFFFAFA's Avatar
JEFFFAFA
According to Holley the equation to figure this out is:
Engine CID (460) X max RPM (you plan on spinning) divided by 3456.
Old Jan 31, 2014 | 01:53 PM
jim collins
My understanding is the Summit carb is cloned off of a Holley . So I assume the linkage brackets on the drivers side is the same ? The reason i need to find out is i will need to use the AOD , TV cable corrector plate made for the Holley . If not them my trany will not shift correct and i will have to keep the Edelbrock it's using now.
Old Jan 31, 2014 | 02:20 PM
HIO Silver's Avatar
HIO Silver
Lemme add that the equation above assumes 100 percent VE or "Volumetric Efficiency". Pure race engines typically achieve upwards of 90-95 percent whereas well-tuned street/stock engines generally achieve around 80 to 85 percent. Therefore, multiply the end result by .80 or .85 as a rule of thumb to size the carb... upsize slightly if the engine has a lumpy (over .480 lift) camshaft.
F-250 restorer
Mar 8, 2013 02:21 PM
teederj2002
Nov 12, 2004 10:54 PM
FERacing66
25
Jul 31, 2004 06:08 AM
351 power
Oct 15, 2003 01:10 PM
