High Idle Mod
Old Jan 28, 2014 | 08:48 PM
polaris_5256's Avatar
polaris_5256
High Idle Mod
Hello all, I am trying to do the high idle mod on my 2004 6.0 with an auto trans. I have located the wires and for kicks and giggles I put my meter on the power supply the white with blue stripe above the obd2 port and it is dead. Could it possibly be as simple as a fuse? and which fuse?
Thanks, Mike
Old Jan 28, 2014 | 09:16 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Check Fuse 12
Josh
Old Jan 28, 2014 | 10:04 PM
polaris_5256
Ok thanks, I will check that tomorrow after work and post back.
Thanks, Mike
Old Jan 28, 2014 | 10:15 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Check fuse #29 too. I can't remember if that's from the pre-04 or post-05 wiring guide though.
Old Jan 29, 2014 | 02:01 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Did you meter the other wire above fuse block too?
Old Jan 29, 2014 | 06:28 AM
Bullitt390's Avatar
Bullitt390
???? The light blue/white wire is right behind the OBD connector. It's part of the DLC circuit and tied into the cigarette lighter/OBD port.
Josh
Old Jan 29, 2014 | 12:53 PM
amdriven2liv
Josh
LOL, brain fart here Josh!
Don't know why I was thinking the power supply was on the other wire.
Old Jan 29, 2014 | 06:42 PM
polaris_5256
Ok so it was fuse 29, got it replaced and wired in, but the idle switch does nothing it is properly grounded and with a test light checked made sure i had the wires properly on the switch (supply is hot when ignition is on) (load is controlled by the switch) (ground is well ground). I tried without the parking brake on and with the parking brake on and it doesn't do anything. I am fairly certain I am in the correct wire (orange white)
Thanks, Mike
Old Jan 29, 2014 | 06:55 PM
Bullitt390's Avatar
Bullitt390
Solid orange is PTO, Purple with Green is Battery Charge Protect.
Josh
Old Jan 29, 2014 | 06:59 PM
polaris_5256
Ohhh crap, guess I need to switch that around, I'll post back with the results of getting that changed to the purple green, /embarrassed
Thanks, Mike
Old Jan 29, 2014 | 07:31 PM
polaris_5256
Ok I just looked there is no purple with green in that harness now Im confused
Thanks, Mike
Old Jan 29, 2014 | 08:03 PM
Bullitt390's Avatar
Bullitt390
Thanks, Mike
Look for solid orange wire... No tracers.
Josh
Old Jan 29, 2014 | 08:08 PM
polaris_5256
Ok I got it working now, it was a blue yellow that i needed to tap into and it works perfectly now. Thanks for all the help everyone
Mike
ghott
Jul 24, 2016 06:59 PM
Superduty21
Mar 15, 2012 05:47 PM
Serapis
Dec 9, 2010 06:13 AM
Mlitt12345
Nov 30, 2010 08:07 PM
joe blow
Nov 10, 2009 04:24 PM
