Options for Transfer Case
Old Jan 28, 2014 | 03:32 PM
highoctane74's Avatar
highoctane74
My drivetrain and frame in my truck are from an 85 F-350/460.
T18/BW1345
My transfer case has been making some funny noises. I am debating rebuilding it, or swapping in something else. I am running 4.10's in the rear for towing and it just screams on the highway. I have been looking into a ZF 5 swap as well.
Will my transfer case bolt up to a ZF, or is there a better combo to pick up instead?
Thanks
Old Jan 28, 2014 | 06:20 PM
Franklin2's Avatar
Franklin2
Yes, it will bolt up. If you decide to get a different transfer case, make sure you get the shifter with it, or make sure yours is the same shifter and linkage/length. They also have different output shafts. Some of them are fixed yoke and some of them are slip yoke. If you do not want to change your rear driveshaft, stick with the same transfer case and the same output shaft style.
They will all bolt up to the t18, t19, zf 5 speed, c6, E4OD. It's the other small things you need to worry about. Most of the time the oil level is low, they like to start leaking and no one checks the oil in these things.
Old Jan 28, 2014 | 10:05 PM
highoctane74
Ok thanks. I was just reading that the BW 1356 is a good replacement also. Lots of choices. I have the bolt on flanges and would like to keep it that way.
Oil is good in mine. It had sat for a while so last year I flushed it, drove it then flushed it again. Did that twice, it was pretty dirty in there.
Bulldog f150
Feb 4, 2014 08:07 AM
Danilo
Apr 24, 2010 08:37 PM
darklord
Mar 13, 2010 07:18 AM
harrisford
Feb 16, 2009 09:27 PM
baw289
1978 - 1996 Big Bronco
Jan 26, 2004 08:05 PM
