car gauge pro
Old Jan 28, 2014 | 04:16 AM
jhobbs26's Avatar
jhobbs26
car gauge pro
Anyone who has this app give a run down how to do a buzz test and cyl cont test?
Old Jan 28, 2014 | 06:46 AM
Tugly's Avatar
Tugly
There's been a lot of recent discussion on this very topic. Portable apps are "listeners", they're not ones to give orders. They can read and display PCM commands (like IPR), and PCM data (like ICP and DTCs), but the apps can't tell the PCM what to do. In order for a device, app, or software to do this, they have to pay Ford for access to their proprietary and copyrighted commands. If Car Gauge Pro, Torque Pro, Dash Command, or any other $5 or $6 app could do a buzz test - they'd brag on that like a five-year-old that just learned to tie his shoes: "Lukit what I can do!" They would also make it clear how to access it.
Sorry.
I tried Car Gauge Pro and I was underwhelmed. I shifted my attention to Torque Pro and checked the forums for improving the Ford Enhanced PIDs to get better readings than what can be chosen from the list. I did my own modifications to some of the PIDs, but it's still a work in progress. If you're interested, you can follow along here: [LINK]
Old Jan 28, 2014 | 01:56 PM
jhobbs26's Avatar
jhobbs26
From the description on the GooglePlay store site:
[Enhanced Functions]
✮ Ford (1996-2008) - Check/Clear Faults, Self Test, KOEO, KOER, Diesel Glow Plug/Injector Buzz/Cyl Contribution Test, Outputs On/Off, Low/High Speed Fan Test, and Enhanced Data 1175 PIDS (ISO, PWM, CAN)
And I agree Rich, Torque is way easier to use and better looking, but doing a google search, there are other forums where the members have said they have gotten the car gauge pro to do the test, I was just checking to see if anyone here has an easy tutorial for us FTE members.
Old Jan 28, 2014 | 03:32 PM
Pikachu's Avatar
Pikachu
The below is from here: LINK
- To get it started you have to press the little plug button at the top of the screen.
- Select Ford as the vehicle make.
- Select Powertrain (the first one)
- Select Scan All when it says Select System Type (Ford)
- Select Full Auto Scan (All Pids)
- Choose your device/dongle/ELM
- Allow it to connect
- It will say Available ECU - mine said 10, I just picked it as it was the only option
- Wait for it to scan all the PIDS (and yes, do like I did and think about the battery, fuel pump priming, glow plugs glowing, etc. annoyingly while you wait)
- It will then ask you to save the PID list, just give it a name
- Now, from the Car Gauge home screen press the "settings" button in the top right (three little squares)
- Select OBD Menu
- Select Self Test
- Now select Fan, Outputs, Injector, Glow Plug, CCT, etc.
Old Jan 29, 2014 | 07:01 AM
Tugly's Avatar
Tugly
Well crap... I have homework to do and crow to eat. I'll check back.
Old Jan 29, 2014 | 09:47 PM
Tugly's Avatar
Tugly
Crow sufficiently eaten. [LINK]
pilgrimbizket
Jul 22, 2019 03:18 PM
LCA078
Apr 24, 2018 07:05 AM
DrunkTruck
May 29, 2017 09:00 AM
Jesser02EX
28
Jun 27, 2015 10:38 PM
Tugly
17
Feb 6, 2014 08:44 AM
