Starting problem.
Old Jan 27, 2014 | 09:08 PM
Alex from GA's Avatar
Alex from GA
Starting problem.
'99 Explorer 5.0 doesn't want to start in the cold weather, below 30. After it finally starts it runs great and will start all day. It cranks fast but it doesn't get driven every day.
Old Jan 27, 2014 | 09:34 PM
shorod's Avatar
shorod
It could be a lot of things. I'd start by checking fuel pressure on a cold start to see if it's what it should be. If not, and since it seems to start fine the rest of the day, I'd change out the fuel filter. These are often ignored so there's a good chance yours is due to be replaced anyway. If the fuel pressure is fine, I'd next check the engine coolant temperature via a scan tool to see if it seems reasonable, basically the same temperature as the outside air, plus or minus maybe 15% since it's not really calibrated.
And of course there's the general tune up items such as spark plugs and spark plug wires. It's amazing how much difference replacing worn out spark plugs can make in starting.
-Rod
Old Jan 27, 2014 | 09:40 PM
steve(ill)'s Avatar
steve(ill)
Turn the key on- off - on several times waiting 3 seconds at each spot. Everytime you turn the key on, the fuel pump charges the line. After 5-6 cycles, then turn to "start" and see if that helps. If your pump is weak or you have a slow leak back to the tank, this will build up pressure and possibly start better.
Tabiks
Oct 20, 2022 04:12 PM
Banjo250
1997 - 2003 F150
18
Jul 2, 2019 04:29 PM
omni
Jul 20, 2005 12:18 AM
jbain2
Jun 25, 2003 07:12 AM
bdonalds
Apr 4, 2001 02:16 PM
