1994 F150 300 CID LPG won't start first time
Hi, guys!
Truck:
1994 F150 4.9L + E4OD + RWD
Fuel type:
Gas/LPG
Problem:
Truck won't start when I try it for first time in morning. I have to crank it 2 or 3 times and only then it will start acompanied with stutter and misfire but only in very beginning. Ater 2 sec engine idles normally. If I turn it off and start again - it will start with no problem. Fuel pump works fine. I have no problem start it when its hot. Only when truck hasnt been used for a while I have problem to start it. It is very weird
It cranks very easy but it wont start. I can hold ignition key and crank it for 5 sec and it wont even hit a spark. Only if I release it and start again then it will at least try to hit some spark in cylinders.
Maybe I should make a video and post it here, so you could see what is the problem?
Any help would be greatly appreciated!
Truck:
Fuel type:
Gas/LPG
Problem:
Fuel pump works fine, I assume, because when I drive my truck there is no sign of fuel being not enough. Truck works fine.
Although, I dont know what fuel pressure truck have.
Hm, I havent tried cycling the key few times - i will try it tomorow.
Here is a short video:
Note: This is one of the most nicest cold starts - 99% of the rest are usually worst. As I said before - sometimes I cant even start it (engine cranks just like 00:02 - 00:03 sec of video)
You could have a leaky injector/s. Checking fuel pressure under different conditions will probably reveal a loss of pressure after a hot shut down. Gas in the engine oil would also be another clue. You can put a vacuum pump on the regulator, apply vacuum and check corresponding changes in fuel pressure.
Btw, mileage - 183k miles
edit:
Just changed oil - no gas in it.
Ou, and last year i accidently let my fuel tank go empty and engine stalled... maybe this is somehow connected with my problem?
but changing the fuel filter would rule that out- tank going empty coild have damaged the fuel pump if it was hot out- but normally fuel pumps either work or they dont.
If the pump is dying you would normally get no sound from it, no start, then if you smack the tank with a hammer it comes to life one last time.
but if your pump was going you most likely would be stalling more going down the road or having a real lack of power.
