Yes, If the battery has a bad cell it can cause the alternator voltage to be low or fluctuate. Low voltage leads to poor spark.
To know if a low voltage issue is causing your issues read the voltage across the battery terminals with the engine running. If you are reading a constant 13-14.5 V with the engine running then the battery is not causing your issues. If you are reading less than 13 then have the battery check at one of the auto stores. If the battery tests good and is fully charged then pull your alternator out and have it tested. If that tests good then check you wiring and coil, points, wires. etc
this is how I would go about checking everything
matt
Thanks Matt .. I hoping battery..This truck is costing my son $$$.. lesson learned..He needs to network and research about it..cool truck but has issues monthly. .
Does the truck have an alternator, or a generator? Points and condensor, or electronic ignition? I would say yes, a weak battery will contribute to a poor idle and performance. Not the primary cause, but a factor. Infrequently driven, short trips, means sulfated battery, weak ignition.
Does the truck warm up in a reasonable amount of time? Y blocks are known to be cold-blooded, but that's not really the case exactly. Everything adds up - fouled plugs too, and once they are fouled they don't get un-fouled on their own.
The BEST tool if he has problems, and even if he doesn't, is get a vacuum gage. They cost maybe 20 bucks. Get one with a large face that's easy to read. You don't have to memorize everything they are capable of doing, that's what the manual is for. And the things they can diagnose is amazing. I don't know how anyone can work on these things without one. They are called "the poor man's Sunn machine" for a reason. It will tell you the overall health of the engine. While it's not a compression tester, if a V8 pulls 19 or 20 inches of steady vacuum, then compression is good, no? It will diagnose valve problems. You can set engine timing and carburetor idle mixture accurately, etc.
