Sponsored by: Real Truck
Door Drain Idea
Old Jan 25, 2024 | 01:32 PM
  #31
wkf94025's Avatar
wkf94025
Great suggestions on this thread. I just discovered a bunch of water sloshing around in my driver's door on my 2015 F450. Pulled the aft-most plastic plug pin on the horizontal rubber gasket at the bottom of the door, found the rectangular drain plug, pulled that plug and a LOT of water came out. We've had about 4" of rain the past week, and truck was parked outside during that. Question is where is the water likely coming in? I can provide detailed photos of door fitment, gaskets, etc., but was curious likely entry point, and why only the driver's door? I hear no water when I swing the other three doors.
Old Jan 25, 2024 | 02:51 PM
  #32
nydiver's Avatar
nydiver
Likely the outer window seal across the bottom of the window, a small gap or tear and water puddles all along the edge and runs to the tiny gap and then straight down into the door. Roll the window down and i think you can just pull that strip off and replace it. Look at the new seal before you start and it should be obvious if its a straight up pull or if you have to pop some clips to get it off. You need part #4 https://www.lmctruck.com/1999-16-for...r-weatherstrip
Old Jan 25, 2024 | 02:55 PM
  #33
wkf94025's Avatar
wkf94025
Thanks @nydiver . I looked at that seal yesterday, and not obvious that it's failing to do its job. But its replacement is cheap enough that it's worth trying before the several inches forecast mid next week!
speakerfritz
May 16, 2019 08:05 AM
QwkTrip
2009 - 2014 F150
Jul 27, 2016 04:22 PM
Europhil
2004 - 2008 F150
Apr 20, 2007 09:58 AM
Miramichi_hockey
2004 - 2008 F150
Apr 10, 2006 07:16 AM
PhrEEkSh0w
2004 - 2008 F150
Feb 27, 2004 06:47 PM
