Another great idea from ford
Old May 15, 2019 | 07:58 AM
speakerfritz's Avatar
speakerfritz
Encore to the foam used between metal seams in past years , I noticed today a bunch of water coming out of the door drain hole when I opened my door. I thought this was odd wondering why was the water not already drained. Upon examination it appears the door drain holes are nicely sealed by the door seal resulting in water being able to drain only when you open the door. I checked my rear pax door which I rarely open and water gushed out of the door drain as soon as I opened the door.
i guess the water is needed in case we get thirsty on long trips.
Old May 15, 2019 | 09:53 AM
Joe T's Avatar
Joe T
Been like that since 2015 and same issue with my 2019.
Causes electrical shorts too.
Old May 15, 2019 | 10:09 AM
Desert Don's Avatar
Desert Don
Don’t you remember, back in the 1960’s.....................
FORD has a better idea!!!!!!!!! LOL. That was their advertising line.
Old May 15, 2019 | 10:31 AM
speakerfritz
I’ll have to investigate the door seal. Maybe I can use a soldering gun to melt a hole on the seal where the square drain hole contacts .
Old May 15, 2019 | 11:27 AM
Brent376's Avatar
Brent376
At least they wont rust now
Old May 15, 2019 | 11:58 AM
speakerfritz
It won’t rust becuase only iron will rust
but it will oxidize which is what aluminum does
and salt water will dissolve aluminum in a few hours
during hurricane sandy, the cars that went under for 6 hours only had plastic tabs in the fuse boxes....the aluminum portion of the fuses dissolved .
Old May 15, 2019 | 05:57 PM
NotJustaTruck's Avatar
NotJustaTruck
Yeah, noticed that early on after washing truck. Always have to open door s and drain them. Thought about removing a small piece of the seal but have not bothered to look into it further
Definitely a "err, oops, hmmm" moment for Ford wonder if they promoted the "door designer" yet? Lol. That person or design team is probably in charge of making the new 2020's "more efficient"
Ford needs to hire a team of everyday average Joe's to come in and give the trucks a dose of reality checking by the fellas that actually use them. C'mon Ford get with it!! Lol
Old May 15, 2019 | 06:22 PM
speakerfritz
That would be a great idea
Old May 15, 2019 | 07:39 PM
jimzpsd's Avatar
jimzpsd
Its not really a design flaw, its more like, use your doors more often and it will never become a problem. However, it seems the majority of crew cab owners have four doors is......... "just because", A lot of rear window motors die prematurely from the same reason........no one sits back there and opens the window, so the electric motor rusts out from lack of use and (Ford) gets the blame.
Old May 15, 2019 | 07:56 PM
Crabbman P's Avatar
Crabbman P
If near a dissimilar metal it will corrode. But there are aluminum boats in Bristol Bay Alaska that have been in service for 50+ years.
Old May 15, 2019 | 08:33 PM
xxxsherpa's Avatar
xxxsherpa
Crabbman, are you an ex-crabber out west?
Old May 15, 2019 | 08:37 PM
Joe T's Avatar
Joe T
Maybe but dont feel like it.
Old May 15, 2019 | 09:45 PM
Desert Don's Avatar
Desert Don
Salt solution, electricity, dis-similar metals..........don’t they call this electrolysis??
Old May 16, 2019 | 12:38 AM
Louisville Joe's Avatar
Louisville Joe
Pintos were like that. Only drained when the door was open. Right doors rusted out faster because they were used less.
Old May 16, 2019 | 03:05 AM
Crabbman P's Avatar
Crabbman P
No, but I'm currently still a crabber out east, lol. Chesapeake bay.
