heater controls 05 ford
Old Jan 27, 2014 | 12:04 PM
beckman's Avatar
beckman
Hi everybody having an issue with a 2005 ford truck 4x4
when you turn the **** to defrost you get air coming out of the front vents
and when you turn the **** for front vents you get air coming out defrost any help on this would be great its a 2005 ford f150 4x4
Old Jan 28, 2014 | 05:34 AM
60DRB's Avatar
60DRB
It might be a blend door issue. If your trim level has the automatic temperature control you can run a diagnostic test;
https://www.ford-trucks.com/forums/986532-2008-eatc-self-test.html
Also, a weak battery can exhibit all sorts of weird [electrical] problems.
Old Jan 29, 2014 | 07:51 PM
danorules's Avatar
danorules
This was my problem and solution. Hope it helps
Old Mar 11, 2014 | 12:58 PM
BII Plow Truck's Avatar
BII Plow Truck
It's not the blend door, it's the vent/floor/defrost selector door. There's a cheap fix on eBay.....way better than removing the entire dash as Ford has you do.
jbedsole23
Mar 11, 2014 06:25 AM
joners
May 24, 2010 06:07 PM
75Ford-Hiboy
Nov 8, 2009 03:19 AM
vicsr2
Jul 5, 2006 10:24 PM
Dboss
1997 - 2003 F150
Mar 13, 2005 04:49 PM
