Speedo reading 100 mph
Old Jan 27, 2014 | 10:24 AM
emmagator's Avatar
emmagator
When truck is off Speedo reads 50mph. When doing 50mph it reads 100 mph. Just started this morning. Speed sensor of some kind gone bad?
Old Jan 27, 2014 | 11:29 AM
npccpartsman's Avatar
npccpartsman
its the cluster
Old Jan 27, 2014 | 12:26 PM
Carolina Rig's Avatar
Carolina Rig
A guy in my office just had this issue with his older model chevy avalanche. apparently on those trucks it's a known issue.
Anyway, he sourced the little stepper motors (on ebay) that the speedo, tacho, and other needle gauges use and got someone here to re-solder the new stepper motors in. It fixed his issue.
It sounds like you have the same thing going on with yours.
Someone on this forum can probably give you the motor part numbers.
good luck.
Old Jan 27, 2014 | 01:52 PM
npccpartsman
The thread I read talked about the cluster face warping when it was cold. There was one poster that went as far as sanding the back off the needle. He had to be extremely cautions because the needle wouldn't come off.
Old Jan 27, 2014 | 02:09 PM
emmagator's Avatar
emmagator
I found a tsb on this issue. Seems 05-07 had cluster issues. I also found some services for about $100 to fix issue, they replace the stepper motors. I would like to fix this myself if possible.
Old Jan 27, 2014 | 08:51 PM
emmagator's Avatar
emmagator
Disconnected batteries, Speedo seems to be working properly now. I'll update later.
BRNWAXA
1978 - 1996 Big Bronco
Sep 15, 2017 09:49 AM
2006fordf25060
Jul 28, 2017 02:47 PM
jamien2
19
Jul 21, 2017 02:19 PM
drunknmudder77
Jul 7, 2006 12:23 AM
my375hp140
1997 - 2003 F150
Jul 16, 2005 01:37 PM
