76 F100 shifter problem
Old Jan 26, 2014 | 06:49 PM
SAVOY05's Avatar
SAVOY05
Hello Guys. I have a 76 F100, 3 speed manual on the column. with power steering. I need to know if anyone knows where I can get the replacement steering shaft that goes through the column. It seems like the only ones I can find are for manual steering. Mine has grooves worn in it and I need a replacement. I checked all the local Junk Yards and can't find anything. Thanks for the advice. Alex
Old Jan 27, 2014 | 07:01 PM
SAVOY05's Avatar
SAVOY05
Thought someone could help. I guess not. thanks anyway
Old Jan 27, 2014 | 07:37 PM
VocaTexas's Avatar
VocaTexas
If you can't find another shaft, take the worn one to a machine shop. They can build it up where it is worn and turn it back down to the correct size.
Old Jan 27, 2014 | 08:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Much to my surprise, I found one!
According to the parts catalog, the automatic and 3 spd columns use the same shaft.
Shaft Assy., Steering
73-up F100-350 2WD and power steering w/o tilt from s/n S40,001
D3TZ-3524-D
33 3/8" long 46 knurles on shaft OD for upper bearing
Haven Ford, Haven, KS shows 1 (620) 465-2252
Old Jan 28, 2014 | 07:58 PM
SAVOY05's Avatar
SAVOY05
Thanks Guys. I'll check with the Dealer in KS. and again Thanks.
precisionplumbing55
Mar 25, 2011 10:21 PM
hartski
Mar 21, 2010 12:29 PM
redbulldog
Jan 19, 2003 06:35 PM
mrbassn
Apr 6, 2002 09:45 AM
