egt gauge and probe preference?
Old Jan 26, 2014 | 05:41 PM
gt4660's Avatar
gt4660
Any preferences and ones to avoid? Problems people have encountered.
No tuner but atlas 40 tune in the ficm.
Old Jan 26, 2014 | 05:49 PM
Money-Pit's Avatar
Money-Pit
I've been happy with my Isspro EV2. The Black face/red pointer/black bezel/green lighting matched my dash gauges
Pyrometer 0-1600ºF EV² - Riffraff Diesel Performance
I advise to get the unique drill bit (it's a letter "R" size bit) and 1/8" NPT tap kit when you purchase.
Old Jan 26, 2014 | 06:45 PM
npccpartsman's Avatar
npccpartsman
I've had an Autometer for 8 years with no issues. I would recommend either one.
Old Jan 27, 2014 | 08:13 AM
87crewdually's Avatar
87crewdually
I went outside the norm and got this one on ebay. Came complete and works flawless for over a year now. I even hooked up a little alarm speaker that will go off if I hit a high temp that you set in the gauge. I chose this one because I wanted a clean in dash mounting.
http://pages.ebay.com/link/?nav=item...d=200397678339
Old Jan 27, 2014 | 08:38 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Isspro EV2s are good gauges, and Isspro customer support has always been great for me.
FP, but EGT goes on the other side of the wheel:
Old Jan 27, 2014 | 08:57 AM
MisterCMK's Avatar
MisterCMK
I use the Edge Insight with their EAS pyrometer add on. I have it set to alarm above a certain temp (I forget what I set it at LOL).
Old Jan 27, 2014 | 09:32 AM
Money-Pit's Avatar
Money-Pit
WTF....you have 85-90 psi of fuel pressure?? How did you do that?
Old Jan 27, 2014 | 09:44 AM
texastech_diesel
Token Redneck
It's called the "stacked blue spring mod", you put two blue springs with a Daisy BB in between them into the regulator, and it forces the injectors to run at 92-95psi. Combined with the Hercules PHP FICM tune, it's good for 110HP on the dyno. You have to install ARP's special injector hold down studs or the fuel pressure will blow the injectors right out of the heads.
But seriously, I just need to take another picture of the stupid thing when it's acting right. The holesaw I used was just a little too small, so the gauge was having sweeping issues when I first installed it because of how tightly it fit. Used a sanding drum on a dremel and went around the circle a few times and now it's fine. If you ever have an Isspro EV2 gauge that doesn't home all the way to zero correctly when it first turns on, pull it out of the bezel and see if that fixes the issue.
Old Jan 27, 2014 | 09:58 AM
Money-Pit's Avatar
Money-Pit
Sweeeet! I gotta do this!
Damnit man, that musta been real tight....did ya have to hammer the gauge in the hole?
Old Jan 27, 2014 | 10:07 AM
texastech_diesel
Token Redneck
I didn't feel like it was tight at all, it "popped" into place and seemed alright. Now it's loose enough to rotate slightly in the dash, but doesn't come out any. It might have been more of an "out of round" issue with one spot of pressure at a bad place on the gauge, I drilled the hole from the back in reverse to keep the dash hole clean and might have gone through at slightly a wonky angle. I was doing it with the dash cover on my knees sitting on my couch, so it wasn't squared up in any way to it.
Old Jan 28, 2014 | 06:40 AM
gt4660's Avatar
gt4660
Thanks for the replys!
Jo7.3
20
May 20, 2019 09:07 AM
Rusty_S
17
Feb 24, 2019 08:16 PM
akamacgyver
Oct 9, 2012 01:20 AM
RussB
Jun 6, 2008 11:53 PM
FARM69
54
Jan 21, 2008 01:24 PM
