6.7 first oil change process
Old Jan 26, 2014 | 10:31 AM
F-WhiteThunder's Avatar
F-WhiteThunder
anything special I need to do with this oil change? warm it up drain it from the bottom. 1 or 2 oil filters? anything else? is the reset a pain also? thanks
Old Jan 26, 2014 | 10:46 AM
2ndStroke's Avatar
2ndStroke
Couple videos on youtube if you search for them, pretty easy.
Old Jan 26, 2014 | 11:36 AM
1954oldred's Avatar
1954oldred
All very simple and straight forward...however, have a large opening in your drain bucket as when you pull the drain plug it will flow rapidly
Old Jan 26, 2014 | 11:46 AM
FishOnOne's Avatar
FishOnOne
Here's a video Epic did on changing the oil. The only difference will be yours will have the metal pan/oil plug.
The key item is to use a fully opened drain pan and not one of the enclosed pans with the little drain hole.
Here's another video using the wrong drain pan.
Old Jan 27, 2014 | 10:28 AM
EZDad's Avatar
EZDad
Also be prepared when you remove the oil filter. Oil will flow out around it and it's heavy and slippery. Use two hands when you remove it.
Old Jan 27, 2014 | 05:25 PM
ruschejj's Avatar
ruschejj
If you have 4x4, use a 5gal bucket, drain the oil when it's around 80° (my preference). Then, slide the bucket under the oil filter, unscrew halfway and let it drain for a few mins, then unscrew all the way. It is very slick, takes good effort or two hands to control it. If you wear rubber gloves you can do it without any spilling or drips, not even wash ur hands.
The bucket is my preference. It's nearly full and it easily allows me to pour the used oil back into the gallon bottles so I can take it to recycle place.
Filling I use a big funnel that sticks in the tube and I can keep two hands on the gallon bottle. I never pre fill the oil filter. I always use exactly 13 qts. Very easy 20 minute deal.
Old Jan 29, 2014 | 11:24 AM
98woody's Avatar
98woody
Use a hole punch in the filter before youbremove it. It will drain the filter before you unscrew it.
JonArmy
Aug 27, 2011 03:02 PM
nebmike
6.7L Power Stroke Diesel
20
Jun 16, 2011 09:45 PM
PEI
May 30, 2011 07:55 AM
superduty4x4
Aug 1, 2008 08:27 PM
johnsjsj
Jan 6, 2008 11:11 AM
