First oil change -- DANG!!!
Old Jun 16, 2011 | 12:45 AM
nebmike's Avatar
nebmike
Ok, I've changed a LOT of oil in my time (including in my 6.0 and 6.4 engines). But I swear, the owners manual for this 6.7 truck should have a warning which states: "Step 1, acquire 5-foot diameter kiddy pool and place under truck. Step 2, when removing new-fangled quarter-turn plastic oil plug, be prepared for it to shoot out of your hands followed closely by a torent of hot oil with the approximate pressure of a 2" fire hose! Caution: oil may shoot up to 3 feet and completely miss your brand new 24" diameter, 5 gallon drain pan (which you never should have bought because it will be completely useless in this application)!"
And as a side note, the new drain pan should have a warning that says: "You idiot, 13 quarts of oil is going to come out FAST... and that little hole in the top of this drain pan isnt nearly big enough to keep up with the flow coming out of the truck, so have lots of rags and kitty litter handy because when you realize its about to over flow and you try to stick that new-fangled plastic plug back in, its just going to act like when you put your thumb on the end of a garden hose, and you're going to get sprayed with HOT oil, and the drain pan is going to over flow anyway."
I now return you to your regularly scheduled programming...
Old Jun 16, 2011 | 02:05 AM
kper05's Avatar
kper05
This had me laughing.
We've seen similar stories and I made a mess the first time.
You'll be ready for the next oil change.
Old Jun 16, 2011 | 02:29 AM
mikespecht's Avatar
mikespecht
epic mada a video thats on you tube, you also can find it on fte. many people use a 5 gallon bucket instead of an oil drain pan
Old Jun 16, 2011 | 06:36 AM
EpicCowlick's Avatar
EpicCowlick
LOL, man... wish THAT was on video...
Sorry about the mess but you're not the first. Those little drain pans with the hole in the center just don't cut it. Great for a lot of vehicles but not 13 quarts of high-volume diesel coming at you fast...
Old Jun 16, 2011 | 06:53 AM
Biggziff's Avatar
Biggziff
Funny stuff...here's something that should help
QuickOilDrainValve.com - the best way to change oil
Old Jun 16, 2011 | 06:57 AM
dbc001's Avatar
dbc001
That is some funny chit. I am ROTFLMAO, my wife is ROTFLMAO, and even the dog is ROTFLMAO. I thank you for the morning chuckle!
Old Jun 16, 2011 | 07:12 AM
HossF250's Avatar
HossF250
You are definately not alone...I had that and one more.....the filter slipped out of my hand and fell into the drain pan throwing more oil on the floor and me too.....
I made a bunch of mental notes for the next time....
Old Jun 16, 2011 | 07:33 AM
Marauder92V's Avatar
Marauder92V
Too funny!
Old Jun 16, 2011 | 08:36 AM
Kep4's Avatar
Kep4
Jäger
Welcome to the 6.7 1st Oil Change Club!
I clearly recall my 11 year old son asking, "Doesn't plastic float?", when the drain plug shot through my fingers, splashed into the bucket, and immediately disappeared under a rapidly rising sea of oil!
"No, son, not all plastic items float."
Old Jun 16, 2011 | 08:53 AM
Rutcutter's Avatar
Rutcutter
I just use a 5 gal bucket when I do mine.. Thanks for the laugh cause I think we all have similar stories,I was ready this time with a 5 gal bucket after I saw Epic's video....
Old Jun 16, 2011 | 09:40 AM
rickatic's Avatar
rickatic
I had my dealer change mine and it was the first 6.7 he had seen. I watched him shoot oil across the service bay...I am sure the language used immediately after he lost his grip on the plug was not dealer approved.
Old Jun 16, 2011 | 09:51 AM
marchare011's Avatar
marchare011
That is fun-eee!!! Thanks for starting my day off with a good laugh. My first o/c will be next month some time. I will be prepared.
Old Jun 16, 2011 | 10:11 AM
buckmasters's Avatar
buckmasters
I have the open top pan like Epic used (got rid of the one with the closed top and plug). Can a 5 gal bucket fit under the truck without lifting it?
Old Jun 16, 2011 | 10:52 AM
AlexWV's Avatar
AlexWV
The plastic 5 gal bucket I have just fits without lifting.
It's the kind you can get at Home Depot.
I also have a couple 3.5 gallon plastic pails which are quite a bit shorter
but those would be almost full to the brim so I don't use those.
The other day at O'Reilly I saw a 4 gallon plastic pail. I didn't measure
it but it looked like about the same diameter so it should be shorter. This
might be the ideal oil change pail.
In any case, a pail is totally the way to go.
For the filter I use a regular open drain pan, not the kind that is enclosed
with a hole in the top. Then I pour that into the pail afterwards. Never
spill a drop.
Old Jun 16, 2011 | 11:13 AM
fatboydiesel's Avatar
fatboydiesel
Hillarious post
